- Feb 27, 2003
We're pleased to announce the release of DirectAdmin 1.46.0.
This is a major release with many large changes, so keep an eye out for any issues..
Note: If you're running CustomBuild 2.0 with Php-FPM, you must be using Apache 2.4.10.
All changes are listed here, in the versions system:
directadmin.com/versions.php?version=1.460000
New Features:
Bugfixes:
Plus many more changes.
See the full list for more information.
New Features:
- RoundCube backup/restore
- XFS Quotas, including per-domain quotas using "projects".
- BFM can monitor PhpMyAdmin. Requires manual patch.
- Custom Httpd Config for nginx proxy templates.
- Custom Httpd Config for php-fpmXX.conf files.
- Resellers can now edit User dns without enabling DNS control
- E-Mail Limit notice to also scan php-mail.log to report highest sending php script.
- DS dns records to allow for subdomain zone delegation for DNSSEC
- Ability to include special characters in random password generation
- SpamAssassin Whitelist to be duplicated in domain filter
- Give warning if package contains Inode value that is likely too small
Bugfixes:
- Nginx directory password protection now works much better with php (new per-user nginx_php.conf)
- New template for password protected directories with nginx
- PHP Selector works better for mod_php and suPhp
- Restores fixes where IPv4/6 are changing. Significant changes to dns restore process.
- Changes to system file permissions.
- SHA-256 CSR were generating self-signed certs
- Internal language class segfault if same variable used twice in one internal function call
- Workaround for disabling Chrome's autofill where it doesn't belong
- Clarify the Open Basedir options with php-fpm
- Reseller restore bug: Cannot restore domain.com, it would exceed your Resellers limit
- better Reseller self-limit enforcement
