- Feb 27, 2003
For DirectAdmin 1.40.2, there will be a very useful new feature called "Login Keys".
http://www.directadmin.com/features.php?id=1298
They basically act as additional passwords, except they can be heavily restricted based on several criteria:
- Number of Uses
- Expiry Date
- IPs or IP ranges that are allowed to use them
- Commands they are allowed to run
The main purpose for this feature is to allow any API script to connect to your DA account, to do whatever it needs to do, but to do so more securely, without needing to give out your main password.
Main applications:
- Multi Server Setup
- Billing Software
- Local Scripts
It's also possible to use the password for the main interface for temporary access (eg: technical support). The expiry, IP restrictions, and ability to automatically delete the key once it's finished, make it handy for this purpose.
If you'd like to try it now, grab the latest pre-release binaries:
http://help.directadmin.com/item.php?id=408
Note that it's still in beta testing, as it's quite new, so there may be bugs.
- Number of Uses
- Expiry Date
Main applications:
- Billing Software
- Local Scripts
