./build exim
jkirker
Trying to update exim with custom build and I'm getting the following... I haven't seen this before.
cyrus_sasl is installed.
Any help would be greatly appreciated... Thanks. John
[root@host1 custombuild]# ./build exim
File already exists
MD5 Checksum on exim-4.84.tar.gz passed.
File already exists
MD5 Checksum on exim passed.
File already exists
MD5 Checksum on exim_freebsd passed.
File already exists
MD5 Checksum on exim_debian passed.
Found /usr/local/directadmin/custombuild/exim-4.84.tar.gz
Extracting ...
Done.
--2014-10-30 16:08:43-- http://files.directadmin.com/services/custombuild/Makefile
Resolving files.directadmin.com... 69.30.193.202, 216.144.254.90
Connecting to files.directadmin.com|69.30.193.202|:80... connected.
Length: 48601 (47K) [text/plain]
Saving to: `Local/Makefile'
100%[===========================================================================================>] 48,601 276K/s in 0.2s
2014-10-30 16:08:43 (276 KB/s) - `Local/Makefile' saved [48601/48601]
Trying to make exim...
/bin/sh scripts/source_checks
>>> Creating links to source files...
>>> Creating lookups/Makefile for building dynamic modules
>>> New Makefile & lookups/Makefile installed
>>> Use "make makefile" if you need to force rebuilding of the makefile
make[1]: Entering directory `/usr/local/directadmin/custombuild/exim-4.84/build-Linux-x86_64'
/bin/sh ../scripts/Configure-os.h
/bin/sh ../scripts/Configure-os.c
gcc buildconfig.c
/bin/sh ../scripts/Configure-config.h "make"
make[2]: Entering directory `/usr/local/directadmin/custombuild/exim-4.84/build-Linux-x86_64'
make[2]: `buildconfig' is up to date.
make[2]: Leaving directory `/usr/local/directadmin/custombuild/exim-4.84/build-Linux-x86_64'
Building configuration file config.h
>>> config.h built
>>> version 4.84 #2
>>> exicyclog script built
>>> exinext script built
>>> exiwhat script built
>>> exigrep script built
>>> eximstats script built
>>> exipick script built
>>> exiqgrep script built
>>> exiqsumm script built
>>> transport-filter.pl script built
>>> convert4r3 script built
>>> convert4r4 script built
>>> exim_checkaccess script built
gcc exim_dbmbuild.c
gcc -o exim_dbmbuild
>>> exim_dbmbuild utility built
gcc -DEXIM_DUMPDB exim_dbutil.c
gcc -DCOMPILE_UTILITY os.c
gcc -DCOMPILE_UTILITY store.c
gcc -o exim_dumpdb
>>> exim_dumpdb utility built
gcc -DEXIM_FIXDB exim_dbutil.c
make[2]: Entering directory `/usr/local/directadmin/custombuild/exim-4.84/build-Linux-x86_64/auths'
gcc auth-spa.c
gcc b64decode.c
gcc b64encode.c
gcc call_pam.c
gcc call_pwcheck.c
gcc call_radius.c
gcc check_serv_cond.c
gcc cram_md5.c
gcc cyrus_sasl.c
cyrus_sasl.c:34:23: error: sasl/sasl.h: No such file or directory
cyrus_sasl.c: In function 'mysasl_config':
cyrus_sasl.c:88: error: 'SASL_OK' undeclared (first use in this function)
cyrus_sasl.c:88: error: (Each undeclared identifier is reported only once
cyrus_sasl.c:88: error: for each function it appears in.)
cyrus_sasl.c:90: error: 'SASL_FAIL' undeclared (first use in this function)
cyrus_sasl.c: In function 'auth_cyrus_sasl_init':
cyrus_sasl.c:106: error: 'sasl_conn_t' undeclared (first use in this function)
cyrus_sasl.c:106: error: 'conn' undeclared (first use in this function)
cyrus_sasl.c:107: error: 'sasl_callback_t' undeclared (first use in this function)
cyrus_sasl.c:107: error: expected ';' before 'cbs'
cyrus_sasl.c:134: error: 'cbs' undeclared (first use in this function)
cyrus_sasl.c:139: error: 'SASL_OK' undeclared (first use in this function)
cyrus_sasl.c: In function 'auth_cyrus_sasl_server':
cyrus_sasl.c:207: error: 'sasl_callback_t' undeclared (first use in this function)
cyrus_sasl.c:207: error: expected ';' before 'cbs'
cyrus_sasl.c:208: error: 'sasl_conn_t' undeclared (first use in this function)
cyrus_sasl.c:208: error: 'conn' undeclared (first use in this function)
cyrus_sasl.c:240: error: 'cbs' undeclared (first use in this function)
cyrus_sasl.c:241: error: 'SASL_OK' undeclared (first use in this function)
cyrus_sasl.c:263: error: 'SASL_SSF_EXTERNAL' undeclared (first use in this function)
cyrus_sasl.c:263: error: 'sasl_ssf_t' undeclared (first use in this function)
cyrus_sasl.c:263: error: expected expression before ')' token
cyrus_sasl.c:300: error: 'SASL_IPREMOTEPORT' undeclared (first use in this function)
cyrus_sasl.c:306: error: 'SASL_IPLOCALPORT' undeclared (first use in this function)
cyrus_sasl.c:336: error: 'SASL_CONTINUE' undeclared (first use in this function)
cyrus_sasl.c:380: error: 'SASL_BADPROT' undeclared (first use in this function)
cyrus_sasl.c:386: error: 'SASL_FAIL' undeclared (first use in this function)
cyrus_sasl.c:386: error: 'SASL_BUFOVER' undeclared (first use in this function)
cyrus_sasl.c:387: error: 'SASL_BADMAC' undeclared (first use in this function)
cyrus_sasl.c:387: error: 'SASL_BADAUTH' undeclared (first use in this function)
cyrus_sasl.c:388: error: 'SASL_NOAUTHZ' undeclared (first use in this function)
cyrus_sasl.c:388: error: 'SASL_ENCRYPT' undeclared (first use in this function)
cyrus_sasl.c:389: error: 'SASL_EXPIRED' undeclared (first use in this function)
cyrus_sasl.c:389: error: 'SASL_DISABLED' undeclared (first use in this function)
cyrus_sasl.c:390: error: 'SASL_NOUSER' undeclared (first use in this function)
cyrus_sasl.c:402: error: 'SASL_NOMECH' undeclared (first use in this function)
cyrus_sasl.c:433: error: 'SASL_USERNAME' undeclared (first use in this function)
cyrus_sasl.c:455: error: 'SASL_SSF' undeclared (first use in this function)
cyrus_sasl.c: In function 'auth_cyrus_sasl_version_report':
cyrus_sasl.c:505: error: 'SASL_VERSION_MAJOR' undeclared (first use in this function)
cyrus_sasl.c:505: error: 'SASL_VERSION_MINOR' undeclared (first use in this function)
cyrus_sasl.c:505: error: 'SASL_VERSION_STEP' undeclared (first use in this function)
make[2]: *** [cyrus_sasl.o] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/exim-4.84/build-Linux-x86_64/auths'
make[1]: *** [buildauths] Error 2
make[1]: Leaving directory `/usr/local/directadmin/custombuild/exim-4.84/build-Linux-x86_64'
make: *** [all] Error 2
