Cliff Spark
Maybe a firewall rule in the system is blocking traffic to localhost (127.0.0.1)
Maybe it doesn't like the admin having multiple domain names? All the other users are fine. It is just me that has issues.
Yes of course. I'm forced to use something else while all the other users use your skin.You get the same result with other skin (enhanced for example)?
Feel free to open a support ticket from your Cyberneticos client area.
Javiern, should you add the ability to set send limit on email?
I see. Does it work fine with the others or do you also get the same problem using the other skins?
Modify mail account
Username: @crazynetwork.it
Enter New Password: (Leave blank to just change quota)
Re-Enter Password:
Email Quota (Meg): (Zero is unlimited)
@javiern, i cant see the tab where can be set the send limit per email on.
In standard skin, each user can set for each email account a send limit for that single email account, i wasnt meaning the all-user-related-limit.
Could not verify the skin license.
Please report this problem to your system administrator.
If you are an administrator please click HERE to go directly to the skin administration page.
I have an answer to all these troubles
remove the skin and not use it
sorry to sound rude but a skin should be the least of your troubles![]()
