qiuai
- May 10, 2010
After I update DA to 1.47.0,I can't use my Ftp at all...
first I can't list my files.Then,I fix it.
And now.I can't upload files..
When I try to upload one file,Filezilla tell me,it's start to upload,and waiting...
then,Filezilla tell me that file is already exist,ask me to cover it.I can see this file,and it's size is 0.
then...Ask me to cover again and again and again...
What ever what I try,I still can't upload file.
What I can do now?I'm waiting online.
Thanks.
I update proftpd to 1.3.5,and set filezilla use "FTP over TLS",and it's OK now...
But when I use "normal FTP",still can't upload and cover.
This problem only appears when I use filezilla !!!!!What happened????
#proftpd -n -d 20
- using TCP receive buffer size of 87380 bytes
- using TCP send buffer size of 16384 bytes
- <IfModule>: skipping 'mod_tls.c' section at line 30
- retrieved UID 14 for user 'ftp'
- retrieved GID 50 for group 'ftp'
- <IfModule>: using 'mod_facts.c' section at line 65
- <IfModule>: skipping 'mod_tls.c' section at line 84
- ROOT PRIVS at mod_core.c:304
- RELINQUISH PRIVS at mod_core.c:326
- UseReverseDNS off, returning IP address instead of DNS name
hostip -
hostip - Config for ProFTPd:
hostip - PassivePorts
hostip - TimesGMT
hostip - TimeoutLogin
hostip - TimeoutIdle
hostip - TimeoutNoTransfer
hostip - TimeoutStalled
hostip - TransferLog
hostip - ExtendedLog
hostip - AuthUserFile
hostip - DefaultServer
hostip - AuthOrder
hostip - DeferWelcome
hostip - RequireValidShell
hostip - DefaultRoot
hostip - DirFakeUser
hostip - DirFakeGroup
hostip - UserID
hostip - UserName
hostip - GroupID
hostip - GroupName
hostip - AllowStoreRestart
hostip - AllowRetrieveRestart
hostip - ListOptions
hostip - ShowSymlinks
hostip - Umask
hostip - DisplayLogin
hostip - DisplayChdir
hostip - AllowOverwrite
hostip - IdentLookups
hostip - ROOT PRIVS at mod_delay.c:354
hostip - RELINQUISH PRIVS at mod_delay.c:359
hostip - retrieved group IDs: 50, 503
hostip - setting group IDs: 50, 503
hostip - SETUP PRIVS at main.c:3127
hostip - ROOT PRIVS at main.c:2151
hostip - RELINQUISH PRIVS at main.c:2158
hostip - ROOT PRIVS at main.c:2486
hostip - opening scoreboard '/var/run/proftpd/proftpd.pid'
hostip - RELINQUISH PRIVS at main.c:2512
hostip - ROOT PRIVS at inet.c:348
hostip - RELINQUISH PRIVS at inet.c:411
hostip - ProFTPD 1.3.3c (maint) (built Thu Dec 9 2010 00:54:22 MST) standalone mode STARTUP
hostip - ROOT PRIVS at pidfile.c:48
hostip - RELINQUISH PRIVS at pidfile.c:50
hostip - ROOT PRIVS at main.c:1238
hostip - RELINQUISH PRIVS at main.c:1242
hostip - no matching vhost found for serverip2#21, using 'ProFTPd' listening on wildcard address
hostip (myip[myip]) - ROOT PRIVS at main.c:1086
hostip (myip[myip]) - SETUP PRIVS at main.c:1091
hostip (myip[myip]) - session requested from client in unknown class
hostip (myip[myip]) - performing module session initializations
hostip (myip[myip]) - mod_ident/1.0: ident lookup disabled
hostip (myip[myip]) - ROOT PRIVS at mod_delay.c:1447
hostip (myip[myip]) - RELINQUISH PRIVS at mod_delay.c:1452
hostip (myip[myip]) - mod_log: opening ExtendedLog '/var/log/proftpd/auth.log'
hostip (myip[myip]) - ROOT PRIVS at mod_log.c:1390
hostip (myip[myip]) - RELINQUISH PRIVS at mod_log.c:1392
hostip (myip[myip]) - mod_log: opening ExtendedLog '/var/log/proftpd/access.log'
hostip (myip[myip]) - mod_log: opening ExtendedLog '/var/log/proftpd/hostip.bytes'
hostip (myip[myip]) - ROOT PRIVS at mod_auth.c:133
hostip (myip[myip]) - opening scoreboard '/var/run/proftpd/proftpd.pid'
hostip (myip[myip]) - RELINQUISH PRIVS at mod_auth.c:135
hostip (myip[myip]) - AuthOrder in effect, resetting auth module order
hostip (myip[myip]) - connected - local : serverip2:21
hostip (myip[myip]) - connected - remote : myip:31779
hostip (myip[myip]) - FTP session opened.
hostip (myip[myip]) - dispatching PRE_CMD command 'USER qiuai' to mod_core
hostip (myip[myip]) - dispatching PRE_CMD command 'USER qiuai' to mod_delay
hostip (myip[myip]) - dispatching PRE_CMD command 'USER qiuai' to mod_auth
hostip (myip[myip]) - dispatching CMD command 'USER qiuai' to mod_ratio
hostip (myip[myip]) - dispatching CMD command 'USER qiuai' to mod_auth
hostip (myip[myip]) - dispatching POST_CMD command 'USER qiuai' to mod_delay
hostip (myip[myip]) - dispatching LOG_CMD command 'USER qiuai' to mod_log
hostip (myip[myip]) - dispatching PRE_CMD command 'PASS (hidden)' to mod_core
hostip (myip[myip]) - dispatching PRE_CMD command 'PASS (hidden)' to mod_delay
hostip (myip[myip]) - dispatching PRE_CMD command 'PASS (hidden)' to mod_auth
hostip (myip[myip]) - dispatching CMD command 'PASS (hidden)' to mod_auth
hostip (myip[myip]) - mod_auth_file/0.8.3: using passwd file '/etc/proftpd.passwd'
hostip (myip[myip]) - retrieved UID 506 for user 'qiuai'
hostip (myip[myip]) - no supplemental groups found for user 'qiuai'
hostip (myip[myip]) - user 'qiuai' authenticated by mod_auth_file.c
hostip (myip[myip]) - ROOT PRIVS at auth.c:1252
hostip (myip[myip]) - RELINQUISH PRIVS at auth.c:1254
hostip (myip[myip]) - USER PRIVS 506 at mod_auth.c:1079
hostip (myip[myip]) - RELINQUISH PRIVS at mod_auth.c:1081
hostip (myip[myip]) - Config for ProFTPd:
hostip (myip[myip]) - PassivePorts
hostip (myip[myip]) - TimesGMT
hostip (myip[myip]) - TimeoutLogin
hostip (myip[myip]) - TimeoutIdle
hostip (myip[myip]) - TimeoutNoTransfer
hostip (myip[myip]) - TimeoutStalled
hostip (myip[myip]) - TransferLog
hostip (myip[myip]) - ExtendedLog
hostip (myip[myip]) - AuthUserFile
hostip (myip[myip]) - DefaultServer
hostip (myip[myip]) - DeferWelcome
hostip (myip[myip]) - RequireValidShell
hostip (myip[myip]) - DefaultRoot
hostip (myip[myip]) - DirFakeUser
hostip (myip[myip]) - DirFakeGroup
hostip (myip[myip]) - UserID
hostip (myip[myip]) - UserName
hostip (myip[myip]) - GroupID
hostip (myip[myip]) - GroupName
hostip (myip[myip]) - AllowStoreRestart
hostip (myip[myip]) - AllowRetrieveRestart
hostip (myip[myip]) - ListOptions
hostip (myip[myip]) - ShowSymlinks
hostip (myip[myip]) - Umask
hostip (myip[myip]) - DisplayLogin
hostip (myip[myip]) - DisplayChdir
hostip (myip[myip]) - AllowOverwrite
hostip (myip[myip]) - IdentLookups
hostip (myip[myip]) - ROOT PRIVS at mod_auth.c:1169
hostip (myip[myip]) - opening TransferLog '/var/log/proftpd/xferlog.legacy'
hostip (myip[myip]) - setting group IDs:
hostip (myip[myip]) - RELINQUISH PRIVS at mod_auth.c:1209
hostip (myip[myip]) - USER PRIVS 506 at mod_auth.c:612
hostip (myip[myip]) - RELINQUISH PRIVS at mod_auth.c:616
hostip (myip[myip]) - set TZ environment variable to 'HKT'
hostip (myip[myip]) - Preparing to chroot to directory '/home/qiuai'
hostip (myip[myip]) - ROOT PRIVS at auth.c:1356
hostip (myip[myip]) - RELINQUISH PRIVS at auth.c:1358
hostip (myip[myip]) - Environment successfully chroot()ed
hostip (myip[myip]) - ROOT PRIVS at mod_auth.c:1250
hostip (myip[myip]) - SETUP PRIVS at mod_auth.c:1262
hostip (myip[myip]) - in dir_check_full(): path = '/', fullpath = '/home/qiuai/'.
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_cap
hostip (myip[myip]) - mod_cap/1.0: capabilities '= cap_net_bind_service+ep'
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_readme
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_ratio
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_delay
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_log
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_ls
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_auth
hostip (myip[myip]) - RELINQUISH PRIVS at mod_auth.c:1623
hostip (myip[myip]) - unable to display DisplayLogin file 'welcome.msg': No such file or directory
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_xfer
hostip (myip[myip]) - dispatching POST_CMD command 'PASS (hidden)' to mod_core
hostip (myip[myip]) - dispatching LOG_CMD command 'PASS (hidden)' to mod_log
hostip (myip[myip]) - dispatching LOG_CMD command 'PASS (hidden)' to mod_ratio
hostip (myip[myip]) - dispatching LOG_CMD command 'PASS (hidden)' to mod_auth
hostip (myip[myip]) - USER qiuai: Login successful.
hostip (myip[myip]) - dispatching PRE_CMD command 'CWD /domains/domain.com/public_html' to mod_core
hostip (myip[myip]) - dispatching PRE_CMD command 'CWD /domains/domain.com/public_html' to mod_ratio
hostip (myip[myip]) - dispatching CMD command 'CWD /domains/domain.com/public_html' to mod_ratio
hostip (myip[myip]) - dispatching CMD command 'CWD /domains/domain.com/public_html' to mod_core
hostip (myip[myip]) - in dir_check_full(): path = '/domains/domain.com/public_html', fullpath = '/home/qiuai/domains/domain.com/public_html'.
hostip (myip[myip]) - dispatching POST_CMD command 'CWD /domains/domain.com/public_html' to mod_readme
hostip (myip[myip]) - dispatching LOG_CMD command 'CWD /domains/domain.com/public_html' to mod_log
hostip (myip[myip]) - dispatching PRE_CMD command 'TYPE A' to mod_core
hostip (myip[myip]) - dispatching CMD command 'TYPE A' to mod_xfer
hostip (myip[myip]) - dispatching LOG_CMD command 'TYPE A' to mod_log
hostip (myip[myip]) - dispatching PRE_CMD command 'PASV' to mod_core
hostip (myip[myip]) - dispatching CMD command 'PASV' to mod_core
hostip (myip[myip]) - Entering Passive Mode (1.1.1.1,138,133).
hostip (myip[myip]) - dispatching LOG_CMD command 'PASV' to mod_log
hostip (myip[myip]) - dispatching PRE_CMD command 'STOR 1404.php' to mod_core
hostip (myip[myip]) - dispatching PRE_CMD command 'STOR 1404.php' to mod_ratio
hostip (myip[myip]) - dispatching PRE_CMD command 'STOR 1404.php' to mod_xfer
hostip (myip[myip]) - in dir_check_full(): path = '/domains/domain.com/public_html/1404.php', fullpath = '/home/qiuai/domains/domain.com/public_html/1404.php'.
hostip (myip[myip]) - in dir_check_full(): setting umask to 0022 (was 0022)
hostip (myip[myip]) - dispatching CMD command 'STOR 1404.php' to mod_xfer
hostip (myip[myip]) - connected - remote : myip:31850
hostip (myip[myip]) - dispatching PRE_CMD command 'TYPE I' to mod_core
hostip (myip[myip]) - dispatching CMD command 'TYPE I' to mod_xfer
hostip (myip[myip]) - dispatching LOG_CMD command 'TYPE I' to mod_log
hostip (myip[myip]) - Entering Passive Mode (1.1.1.1,138,63).
hostip (myip[myip]) - dispatching PRE_CMD command 'MLSD' to mod_core
hostip (myip[myip]) - dispatching CMD command 'MLSD' to mod_facts
hostip (myip[myip]) - UseReverseDNS off, returning IP address instead of DNS name
hostip (myip[myip]) - passive data connection opened - local : serverip2:35391
hostip (myip[myip]) - passive data connection opened - remote : myip:18850
hostip (myip[myip]) - dispatching LOG_CMD command 'MLSD' to mod_log
hostip (myip[myip]) - dispatching LOG_CMD command 'MLSD' to mod_facts
hostip - scrubbing scoreboard
hostip - ROOT PRIVS at scoreboard.c:1077
hostip - RELINQUISH PRIVS at scoreboard.c:1079
hostip - ROOT PRIVS at scoreboard.c:1117
hostip - RELINQUISH PRIVS at scoreboard.c:1151
hostip (myip[myip]) - Entering Passive Mode (1.1.1.1,139,183).
hostip (myip[myip]) - connected - remote : myip:31907
hostip (myip[myip]) - Entering Passive Mode (1.1.1.1,138,207).
hostip (myip[myip]) - passive data connection opened - local : serverip2:35535
hostip (myip[myip]) - passive data connection opened - remote : myip:13106
public_html/akcms_section.php'.
hostip - ProFTPD terminating (signal 2)
hostip - ROOT PRIVS at main.c:2014
hostip - ROOT PRIVS at mod_delay.c:1328
hostip - RELINQUISH PRIVS at mod_delay.c:1333
hostip - RELINQUISH PRIVS at main.c:2036
hostip - ProFTPD 1.3.3c standalone mode SHUTDOWN
hostip - ROOT PRIVS at main.c:2043
hostip - deleting existing scoreboard '/var/run/proftpd/proftpd.pid'
hostip - RELINQUISH PRIVS at main.c:2045
hostip (myip[myip]) - ProFTPD terminating (signal 2)
hostip (myip[myip]) - FTP session closed.
Thanks.
#proftpd -n -d 20
hostip -
hostip - TimesGMT
hostip - AuthOrder
hostip - UserID
hostip - UserName
hostip - GroupID
hostip - GroupName
hostip - Umask
