phpmyadmin work on ip, error on domain!
shivahost
Dear Friends,
Please help me solving this problem!
phpmyadmin works on my server following its ip address: http://78.47.80.79/phpmyadmin
but It doesn't work on my domains like: http://www.shivahost.net/phpmyadmin
and it shows following warning:
Warning in ./libraries/session.inc.php#101
session_start(): open(/var/www/tmp/sess_75hh4jsbme2fmvck506e45pic2er16vp, O_RDWR) failed: Permission denied (13)
Backtrace
./libraries/session.inc.php#101: session_start()
./libraries/common.inc.php#349: require(./libraries/session.inc.php)
./index.php#12: require_once(./libraries/common.inc.php)
Are you sure you installed it using CustomBuild? Cause the login page isnt at all the same that CB show.
Also the path, it shouldnt use /var/www/tmp but probably /tmp
I would highly suggest you to re-install it using Custombuild and also check permissions on /tmp
Regards
Ah... thanks Alex! I definitly never saw that feature at all (and is actually quite an old one)...
Thanks for pointing me that out ;)
Regards
EDIT: I did also test it!! OMG i'm getting old xD
Regards
yes I installed it usin CB plagin. but I changed its config to use cookie for login! So login page changed! but in "http" I have this problem too!
it is ok with IP, So I think there is no permission problem!
It depends. What do you see with
./build options
ls -ld [COLOR=#333333]/var/www/tmp/
?[/COLOR]
./build options
Apache: 2.4.12
mod_ruid2: no
ModSecurity: no
htscanner: 1.0.1
Dovecot: 2.2.18
Dovecot configuration: no
AWstats: no
Exim: 4.85
exim.conf update: yes, release 2.1
BlockCracking: no
Easy Spam Fighter no
SpamAssassin: no
ClamAV: 0.98.7
MySQL: 5.5.44
MySQL backup: yes
MySQL backup directory: /usr/local/directadmin/custombuild/mysql_backups
PHP (default): 5.3 as fastcgi
phpMyAdmin: 4.4.10-all-languages
ProFTPD: 1.3.5a
Pure-FTPd: no
RoundCube webmail: 1.1.2
Replace "php.ini" with './build all' and './build php_ini': yes
Replace "php.ini" using type: production
Auto updates/notifications: no
Run "clean" every time: yes
Run "clean_old_webapps" every time: yes
Run "clean_old_tarballs" every time: yes
Show texts in bold: yes
SquirrelMail: 1.4.22
Zend Guard Loader: yes
ionCube loader: 5.0.10
Suhosin: no
and:
drwxrwx--- 2 webapps webapps 69632 Jul 7 19:23 /var/www/tmp/
Do you have any custom templates in /usr/local/directadmin/data/templates/custom/ ? If yes what are they?
Do you have any custom code added through directadmin for the affected virtual host?
What do you see with:
ls -la [COLOR=#333333]/var/www/tmp/ [/COLOR]
Do you have any custom templates in /usr/local/directadmin/data/templates/custom/ ? If yes what are they? Nothing
Do you have any custom code added through directadmin for the affected virtual host? No
[root@box587 conf]# ls -la /var/www/tmp/
total 240
drwxrwx---   2 webapps webapps 163840 Sep 19 19:33 .
drwxr-xr-x. 11 webapps apache    4096 May 20 15:01 ..
-rw-------   1 webapps webapps   1278 Sep 19 19:33 sess_2q4o3g2lhhgeqkhruo7vvis9bgumvu34
-rw-------   1 webapps webapps   1278 Sep 19 05:01 sess_342saujj1suqvd1j4vhqd1accaja096t
-rw-------   1 webapps webapps   1278 Sep 19 16:41 sess_3jreibcgir9no5f7fab62e140ir89bal
-rw-------   1 webapps webapps   1278 Sep 19 05:01 sess_4sgo731q0dkljsg1q3bqh0h92n8oa0l8
-rw-------   1 webapps webapps   1278 Sep 19 02:39 sess_5i9un1rrpk5598g787lb1dmetp61k8fj
-rw-------   1 webapps webapps   1278 Sep 19 02:39 sess_fq2tlgl2385m92899cks190jduq6igjn
-rw-------   1 webapps webapps   1278 Sep 19 19:33 sess_ijg3g5ohctsshcls6936k4mj86g2f5sn
-rw-------   1 webapps webapps   1278 Sep 19 16:41 sess_nlf9g9i5ljc2vo1mjehcrcjfp2atcegc
-rw-------   1 webapps webapps   1278 Sep 19 18:00 sess_o0jd6rl0o1p3rtfi2m1t67tu4r8mhk2s
-rw-------   1 webapps webapps   1665 Sep 19 02:06 sess_q09lq7q57ee21fcc8s3r7h3kgapi8cp6
-rw-------   1 webapps webapps   1278 Sep 19 18:00 sess_r6lp2utacc6cnrhdl4c2f0vrvq2ktfvs
-rw-------   1 webapps webapps  28321 Sep 19 13:58 sess_r773o5a40331tkr1o7ngckjploc0q407
