DirectAdmin 1.48.1 - RC2
DirectAdmin Support
Administrator
Staff member
We're pleased to announce the Release Candidate 1 for DirectAdmin 1.48.1.
http://www.directadmin.com/versions.php?version=1.481000
This is a minor version release, accelerated slightly due to a restore bug on /home/user/imap folders.
but there are other features added in since the last release, so we'll allow some time to try them out before release.
Please post any issues to this thread.
If you do test out any of the changes, please report if they are working for you.
Update: RC2
I've released RC2.
While adding a "trust this device for 30 days" option in the Two-Step Auth feature, I added a proper session cookie expiry.
This also now applies to the main login session file, meaning you can now fully close your browser, go back to DA, and still be logged in (as long as it's within the session expiry).
If you'd like to give this a try, ensure you've got the RC2 binaries, so you'd see "June 20th" in the "./directadmin o" output.
Hi
We encounter the following error after eternity DirectAdmin
unified_ftp_password_file is not set to 1. You must convert before you can use pureftpd
Please read this guide: http://www.directadmin.com/features.php?id=1134
Simulation:
cd /usr/local/directadmin
echo 'action=convert&value=unifiedftp&simulate=yes' >> data/task.queue
./dataskq d1
Conversion:
echo 'unified_ftp_password_file=1' >> conf/directadmin.conf
echo 'action=convert&value=unifiedftp' >> data/task.queue
./dataskq d1
[root@server custombuild]#
DirectAdmin did not start well
[root@server custombuild]# service directadmin restart
Stopping DirectAdmin: [FAILED]
Starting DirectAdmin: [FAILED]
Those are 2 different issues:
1) If you're trying to use pure-ftpd, then do as it says to convert to the unified file format. Pure-ftpd doesn't support the per-IP type ftp.passwd files, so we put all users into /etc/proftpd.passwd (yes it's the proftpd passwd file), and pure-ftpd reads from that.
2) For DirectAdmin, if it doesn't start, use this guide:
http://help.directadmin.com/item.php?id=75
but try this first:
[COLOR=#000000][FONT=courier new]cd /usr/local/directadmin[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]./directadmin b2000
[/FONT][/COLOR]
but try this first:
[/FONT][/COLOR]
Hi
Thanks for the help
But the problem is still persistent
