different phpinfo configs for another user
uberguru
I noticed i have different php.ini file for a user account i created
user1 has the following in phpinfo page
open_basedir no value
but user2 the user which i am having issues with has this in phpinfo page
open_basedir /home/user2/:/tmp:/var/tmp:/usr/local/lib/php/
How can i change that of user2 to look like user1? set to no value?
basically not sure how to edit the php.ini settings for each user because the second user has different php settings as explained above
anyone willing to help?
Basically that depends on what mode of PHP your user has. There are similar threads here on the forums, so please either search the forums or post here your results for
./build options | grep php -i
I am running DirectAdmin 1.40.3 so does that command work for me?
# ./build options | grep php -i
-bash: ./build: No such file or directory
As admin -> section Extra Features -> PHP Configuration
You can Enable/Disable PHP Safe Mode and Open Basedir restriction per domain.
