How to update Directadmin to latest version?
Tommyhara
I want to update Directadmin to latest version of it. How to do this?
What things should I do before updating process without problems?
I want to be sure a thing, it is to make my sites run well after upgraded Directadmin.
Thanks in advance.
From within the admin area of DirectAdmin you click on license and updates and then you click one button and you are done...
If you are having website issues, this will NOT fix them.
If you come back here with the issues you are facing, we can help a bit better, but if your packages on your server are all up to date, then you need to get specific with what you need.
Thanks for suggestions, I would like to update Directadmin to latest versions and its working well.
Btw, is there any way to check versions (php, mysql, apache..) for current version and the latest version?
