Version specific suPHP_ConfigPath
zEitEr
Super Moderator
www.poralix.com
Currently when using suPHP and 2 versions of PHP (both as suPHP), we have globally specified php.ini:
e.g.
suPHP_ConfigPath /usr/local/php53/lib/
in /etc/httpd/conf/extra/httpd-suphp.conf
I'd suggest that you remove the line from the file and move it into:
virtual_host2.conf
virtual_host2_secure.conf
virtual_host2_secure_sub.conf
virtual_host2_sub.conf
the following way:
|*if SUPHP="1"|
                suPHP_Engine |PHP|
                suPHP_ConfigPath /usr/local/php|PHP1_RELEASE|/lib/
                suPHP_UserGroup |USER| |GROUP|
|*endif|
this way we will have a corresponding to a PHP version php.ini with its build extensions. And suphp won't try to load extensions for PHP 5.3 if we switch to use 5.4, 5.5 or other.
e.g.
virtual_host2.conf
the following way:
|*if SUPHP="1"|
                suPHP_Engine |PHP|
|*endif|
Do we need to do it for every account one by one? or it will apply changes on all accounts?
Where is the path for that 4 config files?
