Could not download Databases from Directadmin?
Tommyhara
I don't know there was a wrong option so that made me can not download Mysql database from Directadmin control panel, it's showing 20 Bytes while real my database is 170 MB when I click on Download a database
Also, under my account statistics, it's showing "Databases 0 database unlimited" while I have 5 databases on this account.
This could happen because reasons as following? (since I made some changes)
I copied configs from /usr/share/mysql/my-large.cnf to /etc/my.cnf ?
I changed password for Mysql root and da_admin account?
which points in my.cnf is affecting to this error?
Has anyone faced this issues before? please share your suggestions and support.
Thanks in advance
If you change da_admin's password you should put it into /usr/local/directadmin/conf/mysql.conf and /usr/local/directadmin/conf/my.cnf
Hello Alex,
Both these files I have already updated new da_admin's password when I changed it.
Still getting the issue...
I remembered I made 1 change more
Added this to /etc/my.cnf under [mysqld] (as its using large config file that I copied from)
max_heap_table_size=128M
tmp_table_size=128M
Installed memcached and store sessions with memcached (but i didn't get the problem with this setting in the past)
If I can not find which is affecting on this then I will need to roll back some old configs in some next days.
What if you try to run this:
mysql --defaults-extra-file=/usr/local/directadmin/conf/my.cnf
What result do you get?
Here's the result when ran your command from SSH
ERROR 1045 (28000): Access denied for user 'da_admin'@'localhost' (using password: YES)
If you have /root/.my.cnf with root's password make sure you've got there the following line:
user=root
Otherwise mysql client tries to connect to mysql server as da_admin with root's password.
If /root/.my.cnf is not the case, then make sure you've correct password in /usr/local/directadmin/conf/mysql.conf and /usr/local/directadmin/conf/my.cnf
user=root
see in this folder /root, I don't see the file with name .my.cnf , it's not exist
The content of file /usr/local/directadmin/conf/mysql.conf is
[client]
user=da_admin
password=mypasswordchanged
and
The content of file /usr/local/directadmin/conf/my.cnf is
user=da_admin
passwd=mypasswordchanged
I only updated the password, didn't change anything in these files
With the command
you should see something similar to:
Welcome to the MariaDB monitor.  Commands end with ; or \g.Your MariaDB connection id is 681
Server version: 5.5.46-MariaDB MariaDB Server
Copyright (c) 2000, 2015, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]>
if you still see the error, then try to use this code:
mysql -uda_admin -p
you will be requested to enter password, try it and update us with results.
I am seeing this when tried mysql --defaults-extra-file=/usr/local/directadmin/conf/my.cnf
when tried mysql -uda_admin -p
I typed da_admin's password mypasswordchanged
and I could login and seeing this
Your MariaDB connection id is 61329
Server version: 5.5.41-MariaDB-log MariaDB Server
Copyright (c) 2000, 2014, Oracle, MariaDB Corporation Ab and others.
MariaDB [(none)]>
In your post #8 you posted content of the files, and they are wrong on your server or you mixed them when posting. Make sure you have it correct:
[FONT=monospace]user=da_admin
[/FONT][FONT=monospace]passwd=mypasswordchanged
[/FONT]
and
[FONT=monospace][client]
[/FONT][FONT=monospace]user=da_admin
[/FONT]
and they both might need an empty line at the bottom. Then try and check the things again.
I checked again and found that my password contained character @ or # so that in Linux, it could ignore this.
Changed password and solved the problem.
Thanks Alex for your support!
