Need tokens for internal lang file
bit
Without internal lang tokens hard make universal function for skin programing.
Some situation:
1) This code work fine without use internal lang
|*if NDOMAINSMAX="unlimited"|
	<li><span>|LANG_DOMAINS|:</span>|NDOMAINS|</li>
|*else|
	<li><span>|LANG_DOMAINS|:</span>|NDOMAINS| / |NDOMAINSMAX|</li>
|*endif|
but with internal lang we another word than unlimited.
2) This JS code be work only for english internal lang too:
$("table.list").each(function(){$(this).find("tr:first td:contains('Advanced Search')").parent().remove();});
Be fine if i can use Internal lang Tokens as:
|*if NDOMAINSMAX="`LANG_INTERNAL_COMMAND#66`"|
|*else|
|*endif|
and
$("table.list").each(function(){$(this).find("tr:first td:contains('|LANG_INTERNAL_TABLE#14|')").parent().remove();});
or have more customisation table.
Thank you for help.
I'm not against language tokens. And that's John who to make a decision. I wonder why do you use JS to change structure of tables on a page? Hasn't it more sense to do it on a server side?
Its be examples but current tables in directadmin is not very simple for customization. Some action more easy make on JS than on php and string replace. Be great if we can make new skins without specific patches on another programming languages for customization.
