problem with change something in directadmin.
maxott
Hello guys, i use directadmin 1.47.0 and centos 7 X64
So, when i suspend/unsuspend account, i need to restart apache manually
also when new account is added, i can log in in directadmin, but cant enter FTP. i have to restart everything manually.
and much other problems, directadmin not updating system on changes.
any ideas?
thanks
Make sure you've got directadmin with a license for centos 7. Your issue might be related to a fact that a lic is for centos 6.
ah, yes...
i was using this license on another server with centos 6.
after that i asked them to change IP.
i've just mailed to directadmin. so, they will send me new file and i have install it?
do i need to reinstall/reconfigure directadmin?
i've got the message today.
DirectAdmin has noticed that the file /usr/local/directadmin/data/task.queue is growing in size and not getting processed.
Please see this guide to ensure that your task.queue gets properly processed:
http://help.directadmin.com/item.php?id=107
how can i check if task queue works ok or not?
action=httpd&value=reload
action=httpd&value=restart
action=rewrite&value=pureftp%5Fdb
action=sshd&value=reload
action=named&value=reload
action=directadmin&value=restart
action=update&value=program
action=cache&value=showallusers
action=cache&value=safemode
action=convert&value=cronbackups
action=convert&value=suspendedmysql
action=syscheck
action=addoptions
action=proftpd&value=restart
action=rewrite&value=filter
action=confirm&type=httpd%2Econf&value=%2Fusr%2Flocal%2Fdirectadmin%2Fdata%2Fusers%2Fdevwordpre%2Fhttpd%2Econf
action=confirm%5Fremoved&type=httpd%2Econf&value=%2Fusr%2Flocal%2Fdirectadmin%2Fdata%2Fusers%2Fdevwordpre%2Fhttpd%2Econf
action=update&value=license
action=confirm&type=httpd%2Econf&value=%2Fusr%2Flocal%2Fdirectadmin%2Fdata%2Fusers%2Fimgurge%2Fhttpd%2Econf
action=confirm&type=httpd%2Econf&value=%2Fusr%2Flocal%2Fdirectadmin%2Fdata%2Fusers%2Fawdsml%2Fhttpd%2Econf
action=confirm%5Fremoved&type=httpd%2Econf&value=%2Fusr%2Flocal%2Fdirectadmin%2Fdata%2Fusers%2Fgaigeinfo%2Fhttpd%2Econf
ah, yes...
action=syscheck
action=addoptions
1. make sure crond is running
2. try to run
/usr/local/directadmin/dataskq d800
as root in console. What are the latest 10 lines?
