high load - no report with nginx+apache & php-fpm setup
orkinoks
we are having some random high loads with one of our newly setup servers.
It is built with nginx+apache / php-fpm.
When the load goes high, I get reports similar to one below.
HTML:
One Minute      - 50.51
Five Minutes    - 58.3
Fifteen Minutes - 43.09
top - 18:30:05 up 1 day, 22:05,  0 users,  load average: 50.51, 58.30, 43.09
Tasks: 327 total,   3 running, 324 sleeping,   0 stopped,   0 zombie
%Cpu(s): 23.9 us,  6.2 sy, 10.0 ni, 34.4 id, 24.6 wa,  0.0 hi,  1.0 si,  0.0 st
KiB Mem :  3883128 total,   233544 free,  3261368 used,   388216 buff/cache
KiB Swap:  3905532 total,  1268748 free,  2636784 used.   234092 avail Mem
 PID USER      PR  NI    VIRT    RES    SHR S %CPU %MEM     TIME+ COMMAND
  11 root      20   0       0      0      0 S  5.9  0.0   3:54.43 [rcuos/0]
15233 root      20   0   26572   1772   1148 R  5.9  0.0   0:00.02 /usr/bin/top -c -b -n 1
   1 root      20   0  209880   1840    848 S  0.0  0.0   0:13.49 /usr/lib/systemd/systemd --switched-root --system --deserialize 24
   2 root      20   0       0      0      0 S  0.0  0.0   0:00.54 [kthreadd]
   3 root      20   0       0      0      0 S  0.0  0.0   0:49.73 [ksoftirqd/0]
   5 root       0 -20       0      0      0 S  0.0  0.0   0:00.00 [kworker/0:0H]
   7 root      rt   0       0      0      0 S  0.0  0.0   0:00.00 [migration/0]
As you can see there is nothing actually that can make the load high. I suspected of the disk, and changed the datastore of this virtual machine, but did not solve the problem.(One option is changing the host machine, but it is quite difficult, I ant to make sure that I eliminate every other possibility) I was once able to log in to machine before it hangs totally once and actually saw some httpd prosesses running, event the report I received from message system was empty like above. Is it possible that php-fpm prosesses are not added to the message system notifications under php-fpm option? Or would systemd proses is the murderer even it shows 0 cpu usage? Thanks to nginx, it gives no server-status page with the free version, we are kind a blind with it. Since my "direct admin" is my wife, I can't purchase a nginx license without her permission. :)
thanks in advance for any suggestions, ideas.
Even with nginx on a board you can still see apache's server status page.
Your our output does not have much information, but still too high 24.6 wa I'd rather say. So if it's not your VPS which bringing issue, then it might be a neighbor VPS, which uses too much disk and affects your VPS.
or just consistent write logs that cause the load. top doesnt do its job showing the origin of high load tbh
its really hard to pinpoint the origin of high load
in my cases for high server load was due to google pagespeed caching that it kept being drop and rewritten due to small cache space i assigned.
the othe time was due to constant logging and these things dont show on "top"
add this to ur nginx config and see if that helps? unlikely but still doesn hurt to try
open_log_file_cache max=100 inactive=1m min_uses=1 valid=2m;
access_log /var/log/nginx/access_log combined buffer=16k;
thanks for the reply. I have asked directadmin support to create a help page for nginx status page. They kindly prepared but the info you get from the nginx status page is not useful.
Here is the help page link.
http://help.directadmin.com/item.php?id=605
Is there anything else that you know to get a list of sites causing high load?
