Strange problem
mamadletsgo
iran,tehran
Hello
PHP file is not run in , Blank run
And any code not stored in them
This problem is only one account
How to solve the problem, this user?
thanks
Sorry but i dont get what your probelm is.
May you try to explain differently or post an example?
If the PHP code is not running for a user, most likely PHP for that user is set to Off, so you would need to edit the user and enable it, if this is not the problem, try to explain differently please.
Best regards
Best regards
Everything is normal and correct
But one of the hosts on the server is generally not execute PHP files
When running only a blank page opens
And any php file in this is can not be edited
Usually a whitepage indicate a problem on connect to the DB, check the DB settings in your configurations php file are correct.
Check also the logs in /var/log/httpd/domains/DOMAIN.err.log
Regards
