Why the system load average is too high?
Tommyhara
Hello
Sometimes I got this alert "The system load average is 17.08" in Message System on my web hosting forum http://forumweb.hosting , I tried to find the reasons in log files but have no lucks.
the details
This is an automated message notifying you that the 5 minute load average on your system is 17.08.
This has exceeded the 10 threshold.
One Minute - 63.7
Five Minutes - 17.08
Fifteen Minutes - 5.81
top - 21:47:02 up 17 days, 3:44, 0 users, load average: 63.70, 17.08, 5.81
Tasks: 337 total, 74 running, 263 sleeping, 0 stopped, 0 zombie
%Cpu(s): 3.7 us, 0.6 sy, 0.0 ni, 95.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.4 st
KiB Mem : 2916052 total, 291512 free, 2468816 used, 155724 buff/cache
KiB Swap: 1048572 total, 163640 free, 884932 used. 285744 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
22272 mysql 20 0 1138612 273872 1112 S 56.5 9.4 1649:49 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/lib/mysql/server.xxxx....xxxx.com.err --pid-file=server.xxxx....xxxx.com.pid
9944 webmast+ 20 0 187524 13952 3552 R 13.0 0.5 0:00.21 /usr/sbin/httpd -k start
9701 apache 20 0 192592 17580 2372 S 8.7 0.6 0:00.52 /usr/sbin/httpd -k start
9862 webmast+ 20 0 193856 18396 2616 R 8.7 0.6 0:00.19 /usr/sbin/httpd -k start
9935 apache 20 0 187524 12880 2504 S 8.7 0.4 0:00.19 /usr/sbin/httpd -k start
9937 apache 20 0 190016 15612 2720 S 8.7 0.5 0:00.21 /usr/sbin/httpd -k start
9996 webmast+ 20 0 192064 17668 2728 R 8.7 0.6 0:00.23 /usr/sbin/httpd -k start
10010 apache 20 0 189760 15356 2720 S 8.7 0.5 0:00.16 /usr/sbin/httpd -k start
48 root 20 0 0 0 0 S 4.3 0.0 3:10.25 [kswapd0]
9674 webmast+ 20 0 191552 12868 1940 S 4.3 0.4 0:00.31 /usr/sbin/httpd -k start
9688 webmast+ 20 0 193856 11224 2620 D 4.3 0.4 0:00.26 /usr/sbin/httpd -k start
9694 webmast+ 20 0 193856 11224 2604 D 4.3 0.4 0:00.61 /usr/sbin/httpd -k start
9700 webmast+ 20 0 193856 10304 2236 D 4.3 0.4 0:00.21 /usr/sbin/httpd -k start
9703 webmast+ 20 0 193856 9976 1964 D 4.3 0.3 0:00.23 /usr/sbin/httpd -k start
9730 webmast+ 20 0 193600 13768 2604 D 4.3 0.5 0:00.18 /usr/sbin/httpd -k start
9737 webmast+ 20 0 193600 13020 2616 R 4.3 0.4 0:00.20 /usr/sbin/httpd -k start
9740 webmast+ 20 0 193600 13316 2604 R 4.3 0.5 0:00.19 /usr/sbin/httpd -k start
9743 webmast+ 20 0 193856 14280 2612 D 4.3 0.5 0:00.21 /usr/sbin/httpd -k start
9745 webmast+ 20 0 193856 13668 2612 R 4.3 0.5 0:00.21 /usr/sbin/httpd -k start
9748 webmast+ 20 0 193856 13844 2608 D 4.3 0.5 0:00.21 /usr/sbin/httpd -k start
9788 webmast+ 20 0 193856 12544 2020 R 4.3 0.4 0:00.17 /usr/sbin/httpd -k start
9792 webmast+ 20 0 194112 14220 2640 R 4.3 0.5 0:00.26 /usr/sbin/httpd -k start
9795 webmast+ 20 0 193856 14136 2604 R 4.3 0.5 0:00.22 /usr/sbin/httpd -k start
Automated Message Generated by DirectAdmin 1.50.0
Can any one know which made my hosting overload?
Maybe your Mysql service is running out of resources.
Check how much procces are running by executing the next SQL:
SHOW FULL PROCESSLIST
I don't know your traffic so i can be caused by multiple things.
Could be caused by overhead maybe you have to repair and optimize your tables.
This is what i execute in a crontab:
mysqlcheck -uda_admin -p`grep "^passwd=" /usr/local/directadmin/conf/mysql.conf | cut -d= -f2` -a --auto-repair --all-databases -s > /dev/null 2>&1 &&
mysqlcheck -uda_admin -p`grep "^passwd=" /usr/local/directadmin/conf/mysql.conf | cut -d= -f2` -c --auto-repair --all-databases -s > /dev/null 2>&1 &&
mysqlcheck -uda_admin -p`grep "^passwd=" /usr/local/directadmin/conf/mysql.conf | cut -d= -f2` -r --auto-repair --all-databases -s > /dev/null 2>&1 &&
mysqlcheck -uda_admin -p`grep "^passwd=" /usr/local/directadmin/conf/mysql.conf | cut -d= -f2` -o --auto-repair --all-databases -s > /dev/null 2>&1
The other thing i would suggest is tuning your mysql server by using the next program, its an open source mysql tuning adviser (always keep an backup when you make change in your /etc/my.cnf)
http://mysqltuner.com/
Hope this could help you
Optimizing tables wont do much of they have slow poorly written sql queries.
You need to look at the following url and try to narrow down what site is causing the load.
http://help.directadmin.com/item.php?id=91
Thanks you guys for your suggestions
I think I found out the problem why it makes my server overload.
I putted 2 high traffic sites in a hosting so they are twice resource. I have just buy a new VPS and moved a site to it so I rarely face the problem overload on my hosting.
Regards,
Tommy
