Install Directadmin on a new VPS?
Tommyhara
I am going to buy a new VPS and use it instead of my current VPS
My question is, Can I use DA licence that installed on old VPS to setup Directadmin on new VPS without problems?
Of course, I just want to test new VPS with DA, if its ok, then I will update DA license for new VPS and cancel old VPS
what things will happen when I use DA license to install on new VPS (that using for old VPS), my Directadmin will be suspended immediately?
I just need some days to test new VPS with DA before moving my sites to it.
Please advise me. Thanks
You cannot install DA on the new VPS if you dont change the IP/OS on the license, the installation will fail.
What you can do and i suggest is request a demo license to DA (is a 30 day trial one), and once your test has done inform DA and ask them to switch your old license to the new VPS (providing the IP/OS), than you can manually update your license on DA using this guide: http://help.directadmin.com/item.php?id=30
Regards
Yes I will change to install DA on new VPS ( just testing for some days)
But I am wondering what will happen with Directadmin (control panel) on old VPS, will it be suspended immediately? or can not I use it?
Regards
Honestly I got this in the past and had a temporary licence for 30 days to test somthings with new VPS
but some months ago, I tried to contacted DA support again for trial (temporary) license for some days but I got no responses...so I think it could not work with this way any more.
Have you tryed to open a ticket to DA and ask for a temp license explaining them what's that for?
The way you're suggesting may work, but it also may break the term of use, i wouldn't suggest you to go that way.
Regards
License will expire within next 30 days. Just update license to have 30 days before to change IP in it.
