- Feb 27, 2003
I've released Easy Spam Fighter 1.11.
This release has added support for default file extension blocking, and has the ability to extract and scan a zip file for any malicious extensions.
Main new file is here:
http://files.directadmin.com/services/easy_spam_fighter/1.11/check_mime.conf
with the zip scanning script here:
http://files.directadmin.com/services/easy_spam_fighter/1.11/exim_check_attachment.sh
This change requires the new exim.conf SpamBlocker 4.4.3 or newer.
Default extensions that are blocked:
and the zip scan will block zips with:
which may need to be tweaked depending on the consensus.
Note that the mime type blocks are smtp-time blocks, so if an email is rejected, the sender should be notified, so adjustments can be made to the payload, or to the scripts.
.exe|\.pif|\.bat|\.scr|\.lnk|\.com|\.vbs|\.cpl
bat|btm|cmd|com|cpl|dat|dll|exe|lnk|msi|pif|prf|reg|scr|vb|vbs|url|zip|js
