Ssl randomly serving localhost cert instead of domein cert
VincentM
Hi All,
We have multiple websites running with a lets encrypt cert on centos 6.
most of them are working fine and are serving the right certificate.
but a few of the sites are randomly returning the localhost certificate resulting in a ssl error.
this happens about 1 out of 20 times i load the page.(different pc's and phones)
www.sslcheck.nl also indicates the same problem when i continuously request a certificate check.
the wierd thing is that we only see this problem at 3 domains of the 8 domains. all domains are configured with the same method.
private_html links to public_html and ssl certificate is requested with the lets encrypt option in directadmin.
Hope that you guys can help me,
Vincent,
Hello Vincent,
Make sure to restart apache with kill -9 if necessary, and rebuild/update apache if it does not help.
Hello Vincent,
Thank you for the fast response.
restarting the httpd via ssh did the trick, i had already done this with the service tab in directadmin but that was apparently not working.
all seems to be working fine now.
thank you for your help.
Vincent
