Can not add Memcached back?
Tommyhara
Before upgraded to PHP7, I used PHP5.6 and installed Memcached successfully on my VPS and used it.
But, after installed PHP7
I got this error on PHP7
[root@serverh ~]# php -v
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20131226/memcache.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20131226/memcache.so: cannot open shared object file: No such file or directory in Unknown on line 0
I downgraded PHP back to PHP 5.6
But now the error is still appearing when I added
extension=memcache.so
to
/usr/local/lib/php.ini
on PHP 5.6, the error is:
PHP 5.6.25 (cli) (built: Sep 13 2016 01:27:52)
Copyright (c) 1997-2016 The PHP Group
Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
    with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
Now I can not use Memcached on PHP 5.6 like before.
Does any one know how to solve this problem?
Thanks in advance!
You need to rebuild the extension after PHP version changes.
oh this is the first time I've ever heard about this, i think it can solve my problem with memcached.
Can you guide me on how to rebuild the extension after PHP version changes?
Thanks zEitEr!
It would mean that
pecl install memcache
it showed this
[root@server ~]# pecl install memcache
pecl/memcache is already installed and is the same as the released version 2.2.7
install failed
failed with an error. You need to build the extension manually with phpize and the others. I won't post here commands to run as they already were posted many times, and an example can be found here:
https://help.directadmin.com/item.php?id=400
Thanks I am looking into this.
I found a post mentioned to recompile php
http://forum.directadmin.com/showthread.php?t=24448
at step 3 but it didn't show in details.
Hello zEitEr,
from this link
you mean I should install memcached this way
yum install libevent libevent-devel
cd /usr/local/src
wget https://memcached.org/files/memcached-1.4.31.tar.gz
tar xvzf memcached-1.4.31.tar.gz
cd memcached-1.4.31
./configure
./configure --enable-threads --enable-64bit
make && make install
I run to this step and restart memcached
service memcached start
also, tried to add
extension_dir="/usr/local/lib/php/extensions/no-debug-non-zts-20131226/"
to php.ini
restart apache to reload php.ini
service httpd restart
but when check php -v
still the same result and its still error
also check with phpinfo() there no memcache module there.
PHP 5.6.25 (cli) (built: Sep 13 2016 05:39:46)
maybe I need to reinstall Directadmin?
but this will consume more time.
