Apache/2.4.23 (Unix) OCSP Stapling
ssgill
Hello i am trying to enable stapling on Apache/2.4.23.
1) /etc/httpd/conf/extra/httpd-ssl.conf
# Specify cached response location (must be outside <VirtualHost>)
SSLStaplingCache shmcb:/tmp/stapling_cache(128000)
before
<VirtualHost _default_:443>
2) /usr/local/directadmin/data/users/useraccount/httpd.conf
<VirtualHost XXX.XXX.XX.154:443 >
<IfModule headers_module>
        # Use HTTP Strict Transport Security to force client to use secure connections only
        Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains"
</IfModule>
	SSLEngine on
    # Enable SSL & OCSP Stapling
        SSLUseStapling on
Tried this edit in httpd-ssl.conf as well but still getting
OCSP response: no response sent
Have all the certificate files linked in domin httpd.conf
SSLCertificateFile /usr/local/directadmin/data/users/userdomain/domains/userdomain.com.cert
SSLCertificateKeyFile /usr/local/directadmin/data/users/userdomain/domains/userdomain.com.key
SSLCACertificateFile /usr/local/directadmin/data/users/userdomain/domains/userdomain.com.cacert
Restart Apache
Any thing i am doing wrong or missing.
Thanks for your time and effort.
Figured it out.
First i was testing against domain on shared IP (SNI). Have not found concrete answer if it works for shared ip and/or if it requires special setup.
Domain on their own IP validates.
Figured it out.
I am tryting to set-up OCSP Stapling and I changed all files, but still getting OCSP response: no response sent.
What exactly did you change to remove/disable the domain on shared IP?
I already disabled SNI using enable_ssl_sni=0. But it is still not working.
What am I missing?
EDIT:
Is HTTP/2 required for OCSP Stapling?
