Multi-IP per domain
shadowq
Hi there,
I've just set up a new DA VPS on a new node. It's the exact same OS and DA version, however I'm having a problem with trying to use multi-ip per domain.
I've ensured "unified_ftp_password_file" is set to 1 in directadmin.conf (and confirmed with ./directadmin c).
It's a fresh install of DA done this morning, with users imported since.
Any ideas? Thanks.
What exactly does not work? At what protocol? What errors do you get?
That would have helped, sorry! I am given no option to add / view current IP addresses associated with that domain. The options are completely missing.
1. Make sure you have mutliple IPs at admin level assigned to your reseller
2. Make sure your reseller has mutliple IPs at his level with either free or shared status
3. Make sure to use the default/native enhanced skin for Directadmin.
And provide a screenshot of what you see there on user-edit page.
Thanks Alex. I was modifying a user made under "admin" reseller account, but assumed that IPs wouldn't need to be assigned to the "admin" reseller. Simply assigning them solve the problem.
Thanks for your help!
