Tootle
 - Sep 1, 2011
SRV1: CentOS 5.11 - BIND 9.3.6-P1-RedHat-9.3.6-25.P1.el5_11.10
SRV2: Centos 7 - BIND 9.9.4-RedHat-9.9.4-29.el7_2.4 (Extended Support Version)
after sync multiserver zones from SRV2->SRV1
service named fails to start on SRV1
now: because of SPF field which must be TXT type on earlier version of BIND? So, everytime SRV2 will sync with SRV1 if I DID NOT correct manually records in .db files named won't start?
	echo "action=rewrite&value=named" >> /usr/local/directadmin/data/task.queue
	$ service named restart
/var/named/domain.com.db:43: unknown RR type 'SPF'
dns_master_load: /var/named/domain.com:43: syntax error
dns_master_load: /var/named/domain.com.db:43: syntax error
zone domain.com/IN: loading master file /var/named/domain.com.db: unknown class/type
_default/domain.com/IN: unknown class/type
                                  [FAILED]
