S sansak Verified User Joined Jun 23, 2007 Messages 49 Nov 25, 2016 #1 Hello, I've debian8 + DA on my server, today I used roundcube to send email, but I cant sent it , it shows Sending message... I've changed to squirrelmail , it can send email. How can I fix this issue? Thank you.
SeLLeRoNe Super Moderator Joined Oct 9, 2004 Messages 6,245 Location A Coruña, Spain Nov 25, 2016 #2 You should check the logs first, the roundcube ones are in /var/www/html/roundcube/logs Also, have you tryed to rebuild roundcube? Best regards
S sansak Verified User Joined Jun 23, 2007 Messages 49 Nov 26, 2016 #3 Hello, There are no logs files , and I've tryed to rebuild roundcube already. It's stilll has the problem.||
SeLLeRoNe Super Moderator Joined Oct 9, 2004 Messages 6,245 Location A Coruña, Spain Nov 26, 2016 #4 Are you using a custom config for roundcube? Is there anything in: /usr/local/directadmin/custombuild/custom/roundcube ?
S sansak Verified User Joined Jun 23, 2007 Messages 49 Nov 26, 2016 #5 SeLLeRoNe said: Are you using a custom config for roundcube? Is there anything in: /usr/local/directadmin/custombuild/custom/roundcube ? Click to expand... There are notthing in this folder , I dont use any custom config for roundcube.
SeLLeRoNe Super Moderator Joined Oct 9, 2004 Messages 6,245 Location A Coruña, Spain Nov 27, 2016 #6 Are you able to connect to: localhost:25 localhost:587 localhost:465 If you try with telnet? Best regards
S sansak Verified User Joined Jun 23, 2007 Messages 49 Nov 27, 2016 #7 SeLLeRoNe said: Are you able to connect to: localhost:25 localhost:587 localhost:465 If you try with telnet? Best regards Click to expand... Hello SeLLeRoNe, I can telnet these three ports sir.
SeLLeRoNe Super Moderator Joined Oct 9, 2004 Messages 6,245 Location A Coruña, Spain Nov 28, 2016 #8 What error do you exactly get when you try to send an email into Roundcube?
S sansak Verified User Joined Jun 23, 2007 Messages 49 Nov 28, 2016 #9 It cant send email out , it show Sending message.......
