disable Apache MultiViews and some options ? how ?
eurobia
i am trying to run a fiverrscript and i need to have these
Apache MultiViews disabled
Ability to run PHP from the command line (CLI) with exec()
Ability to execute background processes with exec("binary > /dev/null &")
i wonder how to do that with DA because i could do it easily with cPanel and Zpanel before
you can check my website to see the error that i get
www.5co.us
There is neither a button nor a checkbox to disable it with one-click, you need to customize httpd.conf for the needed domain:
- Adding custom httpd.conf code to the VirtualHosts of a domain
https://help.directadmin.com/item.php?id=3
- Apache Options Directive
http://httpd.apache.org/docs/2.4/mod/core.html#options
It should work by default, unless you ran ./build secure_php which disables exec();
And again It should work by default, unless you ran ./build secure_php​ which disables exec();
What do you see with
php -i | grep disable_functions
php --ini
replay
thanks alot for your help, for MultiViews i could find it and do it and for the commands i get these results
[root@sv2 ~]# php -i | grep disable_functions
disable_functions => no value => no value
[root@sv2 ~]# php --ini
Configuration File (php.ini) Path: /usr/local/lib
Loaded Configuration File: /usr/local/lib/php.ini
Scan for additional .ini files in: (none)
Additional .ini files parsed: (none)
still couldn't run my script :/ same problem
PHP settings (on your server) do not forbid using exec(), so it must be wrong path to the binary (or the binary is not installed), if it does not work properly.
