Let's encrypt no certificat
toktokcity
The Netherlands
Installing a new VPS nginx_apache, php 7.1, everything seems to work fine, but generating certificats gives the following result:
I did add lets encrypt to directadmin.conf, restart, did a rewrite_configs.
HTML:
Cannot Execute Your Request
Details
Getting challenge for arjenkorevaar.nl from acme-server...
Nonce is empty. Exiting. dig output of acme-v01.api.letsencrypt.org:
api.letsencrypt.org.edgekey.net.
e981.dscb.akamaiedge.net.
23.62.131.169
Full nonce request output:
There is not much information to do research with...
Hoping for someone with a brilliant idea :-)
Do you have the newest letsencrypt.sh file installed? Last time I checked it should be version 1.0.4:
./build versions
./build letsencrypt
Fixed. Changed PHP 7.1 from PHP-FPM to MOD_PHP and enabled mod_ruid2 again.
So PHP-FPM doesn't work with LetsEncrypt?
And yeah, just got the same error trying to generate a server name certifcate.
23.211.237.51
It is working fine here with PHP-FPM 7.1. Are you using letsencrypt=1 or 2 in your directadmin.conf?
