Let's Encrypt script from Directadmin fails with OpenSSL 1.1.0
zEitEr
Super Moderator
www.poralix.com
Let's Encrypt script from Directadmin fails with OpenSSL 1.1.0 with the error:
Invalid command 'sha'; type "help" for a list.
OpenSSL 1.1.0:
# /usr/bin/openssl help 2>&1 | grep sha
md5               mdc2              rmd160            sha1
sha224            sha256            sha384            sha512
has no sha command.
OpenSSL 1.0.2:
# /usr/local/ssl/bin/openssl help 2>&1 | grep sha
sha               sha1
Could you please add a check of OpenSSL version to adjust command depending on OpenSSL version?
Working with OpenSSL 1.1.0:
THUMBPRINT=`echo -n "${FOR_THUMBPRINT}" | tr -d ' ' | ${OPENSSL} sha256 -binary | base64_encode`
Thanks, I've added 1.0.6, but not yet in CustomBuild versions.txt:
http://files1.directadmin.com/services/all/letsencrypt.sh.1.0.6
I'll do some testing first, but any other testing welcome.
New code:
HAS_SHA_256=`${OPENSSL} help 2>&1 | grep -c sha256`
if [ "${HAS_SHA_256}" -gt 0 ]; then
else
    THUMBPRINT=`echo -n "${FOR_THUMBPRINT}" | tr -d ' ' | ${OPENSSL} sha -sha256 -binary | base64_encode`
fi
versions.txt does have 1.0.6 but the file that get downloaded is still 1.0.5 (because CB looks for the .sh file withotu .1.0.6), missing symlink?
Best regards
Best regards
You can do it this way for now.
cd /usr/local/directadmin/scripts/
wget [url]http://files1.directadmin.com/services/all/letsencrypt.sh.1.0.6[/url] -O letsencrypt.sh
chmod 755 letsencrypt.sh
