- Feb 27, 2003
Hello!
We're very pleased to announce the release of DirectAdmin 1.51.0 (*finally*)
This contains numerous new features and bug fixes.
There are also some important security fixes.
Many of the changes are in preparation for the new skin, but if you're a skin designer yourself, you're more than welcome to use them in your skin (ajax, search, etc..)
The full list of changes are here:
https://www.directadmin.com/versions.php?version=1.510000
As for new features, the list is rather huge, so won't list them all:
- dovecot_sni (exim_sni in there, but not quite done yet)
- suspend templates folder
- filemanager supports multiple file[] uploads (can ctrl-click select many files at once, for new skin, enhanced not changed)
New features for the new skin (but any skin can use them)
- skins.conf for per-skin settings (helps DA to control hardcoded things like tables)
- ability to search for commands, users, domain, databases, emails, all in the search bar, and it isn't a pig!
- filemanger recursive search.
- json out for filemanager, tickets, and a few other areas.
Security fixes:
- changes to how we check the referer with logins and certain conditions for logout.
- Awstats will now run as the User. Note this will count against the User's disk usage, so their usage will go up.
Stay tuned, as we'll have good news about the new skin very shortly
Security fixes:
