DirectAdmin v.1.50.1 - LetsEncrypt error
AskNik
Dear Sir/Madam,
When we create a certificate LetsEncrypt there is this error - Must select more than zero LetsEncrypt entries.
Version: DirectAdmin v.1.50.1
Before updating certificates were created properly .
Please change the skin to enhanced, that should fix the problem. It seems the skin you're using is not updated to support DA 1.50.1 version.
Thanks. Now comes this error -
Challenge is invalid. Details: Could not connect to http://_my_domain_/.well-known/acme-challenge/MWZg0FbUF5hWltZluIIBaRL8fmjmkzVRCOtjy2kx3VY. Exiting...
In directadmin.conf settings - letsencrypt=1
log nginx
_my_ip_ - - [03/Jul/2016:21:49:38 +0300] "GET /.well-known/acme-challenge/letsencrypt_1467571776 HTTP/1.1" 200 0 "-" "curl/7.49.1"
66.133.109.36 - - [03/Jul/2016:21:49:40 +0300] "GET /.well-known/acme-challenge/MWZg0FbUF5hWltZluIIBaRL8fmjmkzVRCOtjy2kx3VY HTTP/1.1" 200 108 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
Dear Sir/Madam,
If we disconnect nginx, and left only the apache, in this case, it generates a certificate normally.
If we try to make through the nginx such error appears
  "type": "http-01",
  "status": "invalid",
  "error": {
    "type": "urn:acme:error:connection",
    "detail": "Could not connect to http://_my_domain_/.well-known/acme-challenge/4wH8ExUFaU6WSvCV9HsTvAfk-qP5JlTDQKlCj_A-JYk",
    "status": 400
  "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/nRVGtmUnZ7CZLVR77kKJ6GpX9cpb_S2nGvIwbP7G-lA/156923365",
  "token": "4wH8ExUFaU6WSvCV9HsTvAfk-qP5JlTDQKlCj_A-JYk",
  "keyAuthorization": "4wH8ExUFaU6WSvCV9HsTvAfk-qP5JlTDQKlCj_A-JYk.Mmh2-LDwRdCnyW40RPuE3Be8JnxdX2ruzpShBFjyNxA",
  "validationRecord": [
      "url": "http://_my_domain_/.well-known/acme-challenge/4wH8ExUFaU6WSvCV9HsTvAfk-qP5JlTDQKlCj_A-JYk",
      "hostname": "_my_domain_",
      "port": "80",
      "addressesResolved": [
        "_ip_server_"
      "addressUsed": "_ip_server_"
When switched off modsecurity, everything was working . What can be done in order the plug-in pass the requests?
I encountered the very same issue with nginx_apache config and let's encrypt.
took 9 hours of mine to figure out what is wrong !! The BIG PAIN is that the mod_security of nginx DOESN'T log ANYTHING about this issue and the request appears as a normal request with response 200 in the access_log file of both NGINX and APACHE!!! and if you use curl to download the acme challenge URL with the same browser that Let's Encrypt downloads it, the file appears to be downloaded fine, I even tried to disable both Security engine and Audit engine of mod_security and all of its catalogues in the CWAF admin module but it didn't work as well :|
anyway when I disable mod_security in the file /etc/nginx/nginx.conf:
# include /etc/nginx/nginx-modsecurity-enable.conf
and restart nginx, Let's Encrypt works fine!!
But it's not the right solution and we need to have mod_security enabled :(
I spoke with smtalk about this, and nginx still have a fix for this but not yet released as stable. (or maybe was mod_pagespeed).
smtalk is thinkinging about use the dev version untill they release it as stable, i had exactly the same problem and with smtalk we did found out that was mod_security
Best regards
This still appears to be an issue with 1.512 when running nginx_apache. Is anyone else still encountering, is there a fix given it is some months after the original report of the issue?
What error do you have? Just renewed existing certs on a server with nginx+apache without an issue.
Thanks for replying.
Requesting a new certificate or renewal resulted in:
PHP:
Setting up certificate for a hostname: server1.example.com
Getting challenge for server1.example.com from acme-server...
Waiting for domain verification...
Challenge is invalid. Details: Could not connect to server1.example.com. Exiting..
The hostname has been changed but there is no issue with resolution or firewall rules.
The server worked fine until it was switched from Apache to nginx+apache. Having disabled modsecurity in nginx as per the earlier suggestion it started working again. Whilst it was running Apache only it had worked perfectly too. I tried rewriting configs, etc post the switch to nginx+apache but that did not resolve it.
The nginx and apache logs all showed '200' requests so no obvious error, although clearly mod security was causing the impact as it works since it was disabled in nginx. However, the letsencrypt.sh output indicated a '400' status rather than '200'. If I manually created a file in .well-known/acme-challenge I could access when browsed to using a browser.
The server is running CloudLinux 7.x (latest revision) with DA 1.512. CageFS is enabled too. letencrypt=1 is set in directadmin.conf.
Thanks.
