error custombuild
Boeve webdesign
the Netherlands
Today i had to build some new servers with da / cb, when i run into the following errors:
  • ./install.sh: line 322: unexpected EOF while looking for matching `''
  • ./install.sh: line 367: syntax error: unexpected end of file
The problem is solved with editing the file, but may i asume these files are tested before they are released?
I also try this when trying to install... sigh.
cant you test something out before you release it???
Its a shell script...edit the line and report it to directadmin and get on with your install.
Same problem here with CentOS 6.2 (X86_64).
Has anybody of you reported the issue to Directadmin support in email? If not, I suggest doing that.
As a workaround, I used an older version of install.sh:
#!/bin/sh
#This is the installer script. Run this and follow the directions
DA_SCRIPTS="/usr/local/directadmin/scripts"
CB_OPTIONS=/usr/local/directadmin/custombuild/options.conf
DA_CRON=${DA_SCRIPTS}"/directadmin_cron"
VIRTUAL="/etc/virtual"
CMD_LINE=$1
cd ${DA_SCRIPTS}
#Create the diradmin user
createDAbase() {
	mkdir -p /usr/local/directadmin
	/usr/sbin/useradd -d /usr/local/directadmin -r -s /bin/false diradmin 2> /dev/null
	chmod -f 755 /usr/local/directadmin
	chown -f diradmin:diradmin /usr/local/directadmin;
	mkdir -p /var/log/directadmin
	mkdir -p /usr/local/directadmin/conf
	chown -f diradmin:diradmin /usr/local/directadmin/*;
	chown -f diradmin:diradmin /var/log/directadmin;
	chmod -f 700 /usr/local/directadmin/conf; chmod -f 700 /var/log/directadmin;
	if [ -e /etc/logrotate.d ]; then
		cp $DA_SCRIPTS/directadmin.rotate /etc/logrotate.d/directadmin
	fi
	chown -f diradmin:diradmin /usr/local/directadmin/conf/* 2> /dev/null;
	chmod -f 600 /usr/local/directadmin/conf/* 2> /dev/null;
	mkdir -p /var/log/httpd/domains
	chmod 700 /var/log/httpd
	mkdir -p /home/tmp
	chmod -f 1777 /home/tmp
	/bin/chmod 711 /home
	mkdir -p /var/www/html
	chmod 755 /var/www/html
	SSHROOT=`cat /etc/ssh/sshd_config | grep -c 'AllowUsers root'`;
	if [ $SSHROOT = 0 ]
	then
		echo "AllowUsers root" >> /etc/ssh/sshd_config
	fi
#After everything else copy the directadmin_cron to /etc/cron.d
copyCronFile() {
	if [ -s ${DA_CRON} ] ; then
		cp ${DA_CRON} /etc/cron.d/;
		chmod 600 /etc/cron.d/directadmin_cron
		chown root /etc/cron.d/directadmin_cron
	else
		echo "Could not find ${DA_CRON} or it is empty";
	fi
#Copies the startup scripts over to the /etc/rc.d/init.d/ folder
#and chkconfig's them to enable them on bootup
copyStartupScripts() {
	cp -f directadmin /etc/rc.d/init.d/
	cp -f startips /etc/rc.d/init.d/
	/sbin/chkconfig directadmin reset
	/sbin/chkconfig startips reset
#touch exim's file inside /etc/virtual
touchExim() {
	mkdir -p ${VIRTUAL};
	chown -f mail ${VIRTUAL};
	chgrp -f mail ${VIRTUAL};
	chmod 755 ${VIRTUAL};
	#touch ${VIRTUAL}/domains;
	echo "`hostname`" >> ${VIRTUAL}/domains;
	touch ${VIRTUAL}/domainowners;
	touch ${VIRTUAL}/whitelist_from;
	touch ${VIRTUAL}/use_rbl_domains;
	touch ${VIRTUAL}/blacklist_domains;
	touch ${VIRTUAL}/pophosts;
	echo "0" > ${VIRTUAL}/limit
	echo "0" > ${VIRTUAL}/limit_unknown
	mkdir ${VIRTUAL}/usage
	chmod 750 ${VIRTUAL}/usage
	for i in blacklist_domains whitelist_from use_rbl_domains bad_sender_hosts blacklist_senders whitelist_domains whitelist_hosts whitelist_senders; do
        	touch ${VIRTUAL}/$i;
	done
	chown -f mail:mail ${VIRTUAL}/*;
	chmod 755 ${VIRTUAL}/*
#get setup data
doGetInfo() {
	if [ ! -e ./setup.txt ]
	then
		./getInfo.sh
	fi
getLicense() {
	userid=`cat ./setup.txt | grep uid= | cut -d= -f2`;
	liceid=`cat ./setup.txt | grep lid= | cut -d= -f2`;
	ip=`cat ./setup.txt | grep ip= | cut -d= -f2`;
	LAN=0
	if [ -s /root/.lan ]; then
        	LAN=`cat /root/.lan`
	fi
	if [ "$LAN" -eq 1 ]; then
		$DA_SCRIPTS/getLicense.sh ${userid} ${liceid}
	else
		$DA_SCRIPTS/getLicense.sh ${userid} ${liceid} ${ip}
	fi
	if [ $? -ne 0 ]; then
		exit 1;
	fi
#	wget https://www.directadmin.com/cgi-bin/licenseupdate?lid=${liceid}\&uid=${userid} -O /usr/local/directadmin/conf/license.key --bind-address=${ip} 2> /dev/null
#	if [ $? -ne 0 ]
#	then
#		echo "Error downloading the license file";
#		exit 1;
#	fi
#	COUNT=`cat /usr/local/directadmin/conf/license.key | grep -c "* You are not allowed to run this program *"`;
#	if [ $COUNT -ne 0 ]
#	then
#		echo "You are not authorized to download the license with that client id and license id. Please email [email protected]";
#		exit 1;
#	fi
doSetHostname() {
	HN=`cat ./setup.txt | grep hostname= | cut -d= -f2`;
	/usr/local/directadmin/scripts/hostname.sh ${HN}
	#/sbin/service network restart
getServices() {
	SERVICES_FILE=${DA_SCRIPTS}/packages/services.tar.gz
	if [ -s $SERVICES_FILE ]
	then
		echo "Services file already exists.  Assuming its been extracted, skipping...";
		return;
	fi
	servfile=`cat ./setup.txt | grep services= | cut -d= -f2`;
	DL_SERVER=files.directadmin.com
	if [ -e $CB_OPTIONS ]; then
		DLS=`grep downloadserver $CB_OPTIONS | cut -d= -f2`;
		if [ "${DLS}" != "" ]; then
			DL_SERVER=${DLS}
		fi
	fi
	wget http://${DL_SERVER}/services/${servfile} -O $SERVICES_FILE;
	if [ $? -ne 0 ]
	then
		echo "Error downloading the services file";
		exit 1;
	fi
	echo "Extracting services file...";
	tar xzf $SERVICES_FILE  -C ${DA_SCRIPTS}/packages
	if [ $? -ne 0 ]
	then
		echo "Error extracting services file";
		exit 1;
	fi
doMySQL() {
	rootpass=`cat ./setup.txt | grep mysql= | cut -d= -f2`;
	dbuser=`cat ./setup.txt | grep mysqluser= | cut -d= -f2`;
	userpass=`cat ./setup.txt | grep adminpass= | cut -d= -f2`;
	./mysql.sh $rootpass $dbuser $userpass $CMD_LINE;
./doChecks.sh;
if [ $? -ne 0 ]
then
	exit 1;
fi
doGetInfo
doSetHostname
createDAbase
copyStartupScripts
#copyCronFile #moved lower, after custombuild, march 7, 2011
touchExim
./fstab.sh
${DA_SCRIPTS}/cron_deny.sh
getLicense
getServices
if [ ! -e /usr/local/directadmin/custombuild/options.conf ] && [ -e /etc/redhat-release ] && [ ! -e /etc/init.d/xinetd ] && [ -e /usr/bin/yum ]; then
	yum -y install xinetd
	/sbin/chkconfig xinetd on
	/sbin/service xinetd start
fi
doMySQL
cd ${DA_SCRIPTS}
./phpMyAdmin.sh
cp -f ${DA_SCRIPTS}/redirect.php /var/www/html/redirect.php
${DA_SCRIPTS}/proftpd.sh
${DA_SCRIPTS}/exim.sh
${DA_SCRIPTS}/sysbk.sh
if [ ! -e "/usr/bin/ncftpput" ]; then
       ${DA_SCRIPTS}/ncftp.sh
fi
ADMINNAME=`cat ./setup.txt | grep adminname= | cut -d= -f2`;
/usr/sbin/userdel -r $ADMINNAME;
/bin/rm -rf /usr/local/directadmin/data/users/${ADMINNAME};
${DA_SCRIPTS}/customapache.sh
if [ $? -ne 0 ]
then
	copyCronFile
        exit 1;
fi
#moved here march 7, 2011
copyCronFile
if [ ! -e /usr/local/bin/php ]; then
        echo "*******************************************";
        echo "";
        echo "Cannot find /usr/local/bin/php";
        echo "Please recompile php with custombuild, eg:";
        echo "cd /usr/local/directadmin/custombuild";
        echo "./build all d";
        echo "";
        B64=`uname -m | grep -c 64`
        if [ $B64 -eq 1 ]; then
                echo "This appears to be a 64-bit system.";
                echo "a common cause of http/php compile failures is mentioned here:";
                echo "http://help.directadmin.com/item.php?id=213";
                echo "";
                echo "If you're running CentOS (not freebsd or debian) and applies to you, then type:";
                echo "";
                echo "ln -sf /usr/lib64/libexpat.so /usr/lib/libexpat.so";
                echo "ln -sf /usr/lib64/libm.so /usr/lib/libm.so";
                echo "ln -sf /usr/lib64/libssl.so /usr/lib/libssl.so";
                echo "";
        fi
	exit 1;
fi
./directadmin i
./directadmin p
echo "";
echo "System Security Tips:";
echo "  http://help.directadmin.com/item.php?id=247";
echo "";
DACONF=/usr/local/directadmin/conf/directadmin.conf
if [ ! -s $DACONF ]; then
	echo "";
	echo "*********************************";
	echo "*";
	echo "* Cannot find $DACONF";
	echo "* Please see this guide:";
	echo "* http://help.directadmin.com/item.php?id=267";
	echo "*";
	exit 1;
fi
exit 0;
Paste the code above into /usr/local/directadmin/scripts/install.sh and run sh /usr/local/directadmin/scripts/install.sh.
I have already e-mailed DirectAdmin support, but still wanted to report the problem in this topic as well :)
My solution:
Edit /usr/local/directadmin/scripts/install.sh on line 322 edit the "you're" to "you are" and it worked for me :)
Sorry about that. There was a small bug in install.sh, but should be ok now.
Try running the setup.sh again.
The bug wasn't on line 322, that's just where the matching ended up failing.
It was actually missing " character at the end of 218, which now looks like:
echo "failed to get md5 file: ${SERVICES_FILE}.md5";
This was not caught during the pre-release testing, but has since been resolved.
Error
./build: line 277: unexpected EOF while looking for matching `" '
./build: line 278: syntax error: unexpected end of file
This error occurs after I upgraded to version 1.5.1.3 DirectAdmin and run ./build update
Please help me!
The following command should fix it for you:
wget -O /usr/local/directadmin/custombuild/build files1.directadmin.com/services/custombuild/2.0/custombuild/build
