system broken because upgrade openssl
cRipTz
Almeria (España)
Hi, I have updated openssl on my server and now all is broken.
# openssl version
OpenSSL 1.0.2k  26 Jan 2017
I cant compile from custombuild.
# ./build all d
In file included from /usr/include/openssl/evp.h:66:0,
                 from /usr/include/openssl/x509.h:73,
                 from /usr/include/openssl/ssl.h:156,
                 from ssl_private.h:90,
                 from ssl_engine_mutex.c:31:
/usr/local/include/openssl/opensslconf.h:18:3: error: #error OPENSSL_ALGORITHM_DEFINES no longer supported
 # error OPENSSL_ALGORITHM_DEFINES no longer supported
                 from ssl_engine_kernel.c:31:
                 from ssl_engine_io.c:30:
                 from ssl_engine_init.c:29:
                 from ssl_engine_pphrase.c:31:
                 from mod_ssl.c:27:
                 from ssl_engine_config.c:29:
                 from ssl_engine_log.c:30:
mod_ssl.c: In function 'ssl_cleanup_pre_config':
mod_ssl.c:313:5: warning: implicit declaration of function 'ENGINE_cleanup' [-Wimplicit-function-declaration]
     ENGINE_cleanup();
mod_ssl.c: In function 'ssl_hook_pre_config':
mod_ssl.c:350:5: warning: implicit declaration of function 'ENGINE_load_builtin_engines' [-Wimplicit-function-declaration]
     ENGINE_load_builtin_engines();
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_pphrase.lo' failed
make[3]: *** [ssl_engine_pphrase.lo] Error 1
make[3]: *** Waiting for unfinished jobs....
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_mutex.lo' failed
make[3]: *** [ssl_engine_mutex.lo] Error 1
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_config.lo' failed
make[3]: *** [ssl_engine_config.lo] Error 1
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_io.lo' failed
make[3]: *** [ssl_engine_io.lo] Error 1
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_log.lo' failed
make[3]: *** [ssl_engine_log.lo] Error 1
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_init.lo' failed
make[3]: *** [ssl_engine_init.lo] Error 1
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'ssl_engine_kernel.lo' failed
make[3]: *** [ssl_engine_kernel.lo] Error 1
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:206: recipe for target 'mod_ssl.lo' failed
make[3]: *** [mod_ssl.lo] Error 1
make[3]: Leaving directory '/usr/local/directadmin/custombuild/httpd-2.4.25/modules/ssl'
/usr/local/directadmin/custombuild/httpd-2.4.25/build/rules.mk:75: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/usr/local/directadmin/custombuild/httpd-2.4.25/modules/ssl'
make[1]: Leaving directory '/usr/local/directadmin/custombuild/httpd-2.4.25/modules'
make: *** [all-recursive] Error 1
Help please, I have tried everything....
How do you have update openssl? And enter these commands and post the ouput here:
uname -a
cat /etc/debian_version
./config --prefix=/usr no-threads shared
make
make test
make install
# uname -a
Linux host 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
# cat /etc/debian_version
8.7
# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 8.7 (jessie)
Release:        8.7
Codename:       jessie
Thanks in advance
make
make test
make install
Thanks in advance
Thank you! So you've build OpenSSL version 1.0.2k from the source? Why? We have also update OpenSSL but we using apt-get with a Pin-Priority for OpenSSL from the jessie-backports. Other packages comes from Jessie. Our custombuild still works.
In your post, I see:
I did ls -l /usr/local/include/openssl/opensslconf.h && ls -l /usr/local/include/openssl/ and see (OpenSSL from apt-get):
ls: cannot access /usr/local/include/openssl/opensslconf.h: No such file or directory
ls: cannot access /usr/local/include/openssl/: No such file or directory
Please enter these commands and post the output here:
dpkg --list | grep openssl
hello davydvries
# openssl version
OpenSSL 1.0.1t  3 May 2016
I recompiled it from apt-get (dont work)
# ls -l /usr/local/include/openssl/opensslconf.h
-rw-r--r-- 1 root staff 3919 Mar 20 18:31 /usr/local/include/openssl/opensslconf.h
total 4
-rw-r--r-- 1 root staff 3919 Mar 20 18:31 opensslconf.h
# dpkg --list | grep openssl
ii  libgnutls-openssl27:amd64        3.3.8-6+deb8u4              amd64        GNU TLS library - OpenSSL wrapper
ii  openssl                          1.0.1t-1+deb8u6             amd64        Secure Sockets Layer toolkit - cryptographic utility
Thanks in advance
Hi davydvries
No lucky.
I am trying to compile apache with nghttp2 and dont work...
https://forum.directadmin.com/showthread.php?t=52590
/usr/local/lib_http2/lib/libssl.a(s23_clnt.o): In function `ssl23_connect':
s23_clnt.c:(.text+0x4e7): undefined reference to `sk_value'
s23_clnt.c:(.text+0x4fe): undefined reference to `sk_num'
s23_clnt.c:(.text+0xb80): undefined reference to `sk_num'
s23_clnt.c:(.text+0xbe2): undefined reference to `sk_value'
s23_clnt.c:(.text+0xd17): undefined reference to `OpenSSLDie'
/usr/local/lib_http2/lib/libssl.a(t1_lib.o): In function `tls_decrypt_ticket':
t1_lib.c:(.text+0x41): undefined reference to `HMAC_CTX_init'
t1_lib.c:(.text+0x49): undefined reference to `EVP_CIPHER_CTX_init'
t1_lib.c:(.text+0xd8): undefined reference to `HMAC_CTX_cleanup'
t1_lib.c:(.text+0xe0): undefined reference to `EVP_CIPHER_CTX_cleanup'
t1_lib.c:(.text+0x19d): undefined reference to `HMAC_CTX_cleanup'
t1_lib.c:(.text+0x1bc): undefined reference to `EVP_CIPHER_CTX_cleanup'
t1_lib.c:(.text+0x1d4): undefined reference to `EVP_CIPHER_CTX_cleanup'
t1_lib.c:(.text+0x1dc): undefined reference to `HMAC_CTX_cleanup'
t1_lib.c:(.text+0x279): undefined reference to `EVP_CIPHER_CTX_cleanup'
t1_lib.c:(.text+0x2d4): undefined reference to `EVP_CIPHER_CTX_cleanup'
t1_lib.c:(.text+0x31d): undefined reference to `EVP_CIPHER_CTX_cleanup'
/usr/local/lib_http2/lib/libssl.a(t1_lib.o): In function `ssl_add_clienthello_tlsext':
t1_lib.c:(.text+0x1c97): undefined reference to `sk_value'
t1_lib.c:(.text+0x1cb2): undefined reference to `sk_num'
t1_lib.c:(.text+0x24f3): undefined reference to `sk_value'
t1_lib.c:(.text+0x251c): undefined reference to `sk_num'
t1_lib.c:(.text+0x260c): undefined reference to `sk_value'
t1_lib.c:(.text+0x2636): undefined reference to `sk_num'
/usr/local/lib_http2/lib/libssl.a(t1_lib.o): In function `ssl_parse_serverhello_tlsext':
t1_lib.c:(.text+0x3d1c): undefined reference to `BUF_strdup'
/usr/local/lib_http2/lib/libssl.a(t1_lib.o): In function `ssl_parse_clienthello_tlsext':
t1_lib.c:(.text+0x54ec): undefined reference to `sk_pop_free'
t1_lib.c:(.text+0x54fa): undefined reference to `sk_new_null'
t1_lib.c:(.text+0x556a): undefined reference to `sk_push'
t1_lib.c:(.text+0x5666): undefined reference to `sk_pop_free'
/usr/local/lib_http2/lib/libssl.a(t1_lib.o): In function `tls1_check_chain':
thank you very much
Can you check out with the find command or locate command where OpenSSL state? I think there are files from the source.
Maybe you could look at this? It is explained how you can remove a source package.
