apacha+nginx rewrite_confs fails nginx to start because of alias webapps
Tootle
I want a custom alias for webapp so i did
https://help.directadmin.com/item.php?id=599
result
[root@server][/usr/local/directadmin/custombuild]
$ ./build rewrite_confs
Checking to ensure /etc/httpd/conf/ssl.crt/server.ca is set.
Adding custom webapps from /usr/local/directadmin/custombuild/custom/webapps.list
Added .well-known pointing to .well-known
Added poczta pointing to roundcube
Using 1xx.xx.xx.xx for your server IP
Found /usr/local/directadmin/custombuild/mod_aclr2-1.0.0.tar.gz
Extracting /usr/local/directadmin/custombuild/mod_aclr2-1.0.0.tar.gz...
Installing mod_aclr2-1.0.0...
/var/www/build/libtool --silent --mode=compile gcc -std=gnu99 -prefer-pic -I/usr/local/include  -DLINUX -D_REENTRANT -D_GNU_SOURCE -pthread -I/usr/include/apache  -I/usr/include/apache   -I/usr/include/apache   -c -o mod_aclr2.lo mod_aclr2.c && touch mod_aclr2.slo
/var/www/build/libtool --silent --mode=link gcc -std=gnu99 -L/usr/local/lib   -o mod_aclr2.la  -rpath /usr/lib/apache -module -avoid-version    mod_aclr2.lo
/var/www/build/instdso.sh SH_LIBTOOL='/var/www/build/libtool' mod_aclr2.la /usr/lib/apache
/var/www/build/libtool --mode=install install mod_aclr2.la /usr/lib/apache/
libtool: install: install .libs/mod_aclr2.so /usr/lib/apache/mod_aclr2.so
libtool: install: install .libs/mod_aclr2.lai /usr/lib/apache/mod_aclr2.la
libtool: install: install .libs/mod_aclr2.a /usr/lib/apache/mod_aclr2.a
libtool: install: chmod 644 /usr/lib/apache/mod_aclr2.a
libtool: install: ranlib /usr/lib/apache/mod_aclr2.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin:/sbin" ldconfig -n /usr/lib/apache
Libraries have been installed in:
   /usr/lib/apache
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
chmod 755 /usr/lib/apache/mod_aclr2.so
[activating module `aclr' in /etc/httpd/conf/httpd.conf]
mod_aclr2 has been installed successfully.
Restarting apache.
Restarting nginx.
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
and nginx will not start because it has double definitions in
webapps.ssl.conf and webapps.conf
i have to remove them manually then nginx starts
What's inside /usr/local/directadmin/custombuild/custom/webapps.list ? May you also attach the content of webapps.ssl.conf and webapps.conf ?
[root@server][~]
$ cat /usr/local/directadmin/custombuild/custom/webapps.list
.well-known=.well-known
poczta=roundcube
  location ^~ /.well-known {
                root /var/www/html/;
                index index.php index.html index.htm;
                location ~ ^/.well-known/ {
                        access_log off;
                set $my_server_addr $server_addr;
                if ($server_addr ~ ^[0-9a-fA-F:]+$) { set $my_server_addr [$server_addr]; }
                        proxy_pass http://$my_server_addr:8080;
                        proxy_set_header X-Client-IP      $remote_addr;
                        proxy_set_header X-Accel-Internal /.well-known/nginx_static_files;
                        proxy_set_header Host        $host;
                        proxy_set_header X-Forwarded-For  $proxy_add_x_forwarded_for;
                location ~ ^/.well-known/nginx_static_files/ {
                        access_log  /var/log/nginx/access_log_proxy;
                        alias       /var/www/html/;
                        internal;
        location ^~ /roundcube {
                location ~ ^/roundcube/ {
                        access_log off;
                        proxy_set_header X-Accel-Internal /roundcube/nginx_static_files;
                location ~ ^/roundcube/nginx_static_files/ {
                        internal;
        location ^~ /phpMyAdmin {
                location ~ ^/phpMyAdmin/ {
                        access_log off;
                        proxy_set_header X-Accel-Internal /phpMyAdmin/nginx_static_files;
                location ~ ^/phpMyAdmin/nginx_static_files/ {
                        internal;
        location ~ ^/phpmyadmin {
                rewrite ^/* /phpMyAdmin last;
        location ~ ^/pma {
        location ~ ^/webmail {
                rewrite ^/* /roundcube last;
        if ($request_method !~ ^(GET|HEAD|POST)$ ) {
                return 444;
        location ~ /(\.htaccess|\.htpasswd|\.user\.ini) {
                deny all;
        location ~ /roundcube/(bin|SQL|config|logs|temp)/ {
                deny all;
        location ~ /phpMyAdmin/log/ {
                deny all;
the thing is: when i do a $ ./build rewrite_confs
i've end with additional FULL definitions in
at the bottom of those nginx includes, so I assume it is an append without checking the existence
so now i did:
and
Restarting nginx.
webapps.conf
                        access_log off;
                        internal;
                        access_log off;
                        internal;
                        access_log off;
                        internal;
        location ~ ^/pma { rewrite ^/* /phpMyAdmin last;
                return 444;
                deny all;
                deny all;
                deny all;
                        access_log off;
                        internal;
                        access_log off;
                        internal;
2017/03/24 15:02:07 [emerg] 9304#0: duplicate location "/.well-known" in /etc/nginx/webapps.conf:79
2017/03/24 15:03:03 [emerg] 9337#0: duplicate location "/.well-known" in /etc/nginx/webapps.ssl.conf:79
I must remove those two definitions at the bottom of the files webapps.ssl.conf and webapps.conf then nginx starts OK.
.well-known is managed automatically by DA, if letsencrypt=1 is set, you don't need to have it in webapps.list.
Hmm, first of all I needed to do this,
https://help.directadmin.com/item.php?id=646
because let's encrypt cert generation failed in DA (.well-known)
But the /roundcube alias is also doubled when rewriting confs, so... I don't get it.
Nevertheless, so You're sayin that I shall manually remove
from webapps.list then?
