# ./build versions
Latest version of DirectAdmin: 1.51.4
Installed version of DirectAdmin: 1.51.3
DirectAdmin 1.51.3 to 1.51.4 update is available.
# ./build update_da
Updating DirectAdmin
nothing echoed in the shell, I have to wait for 20 sec. then shell prompt returns
I do again
# ./build versions
Latest version of Let's Encrypt client: 1.0.10
Installed version of Let's Encrypt client: 1.0.10
However, in DA panel msg:
This is an automated message notifying you that the DirectAdmin software has been successfully updated.
which is likely not the case:
# /usr/local/directadmin/directadmin v
Version: DirectAdmin v.1.51.3
It gets more weird:
# ./build update_versions
Updating Let's Encrypt client
Downloading letsencrypt.sh...
--2017-06-11 13:18:56-- http://files.directadmin.com/services/custombuild/all/letsencrypt.sh
Resolving files.directadmin.com (files.directadmin.com)... 69.162.69.58, 216.144.254.90, 208.167.226.3
Connecting to files.directadmin.com (files.directadmin.com)|69.162.69.58|:80... connected.
Length: 22139 (22K) [text/plain]
Saving to: `/usr/local/directadmin/custombuild/letsencrypt.sh'
100%[=========================================================================================================================================================================>] 22,139 --.-K/s in 0.1s
2017-06-11 13:18:56 (177 KB/s) - `/usr/local/directadmin/custombuild/letsencrypt.sh' saved [22139/22139]
[B]Let's encrypt client 1.0.10 has been installed. [/B] (!!??????????!)
Never had this with DA updates before.
Can I manually try to install 1.51.4?
