New IP for access_host in mysql.conf how sync to remote database?
defomaz
Halo,
I use separated database for our directadmin server.
first time I use just single ip block
user=da_admin
passwd=xxxx
access_host=xx.32.%
host=mysql
but Now I need add additional block (access_host1).
user=da_admin
passwd=xxx
access_host=xx.xx.%
access_host1=xx.xx.%
host=mysql
This work for new database, but there is already 100 more database.
How sync new access host ip to old database?
Thank you.
If you're asking how to edit the mysql.conf file on all servers, setting up ssh rsa keys might make that process faster. There is no DA API to edit the mysql.conf file.
https://help.directadmin.com/item.php?id=516
Once scp is setup, a script could be used to root into each box without using a password, then do a regex or direct copy to adjust the file.
If you're just talking about inserting a new IP for each DB listed in DA, then just use the CMD_API_DATABASE to do that:
https://directadmin.com/features.php?id=503
