Problem with Clamd
Mattpl
ZS
Hi guys! I have problem on my Deb with DA. Today i found this error message
exim paniclog /var/log/exim/paniclog on xxx.xxx.com has non-zero size, mail system might be broken. The last 10 lines are quoted below.
2017-06-27 07:45:25 1dPjJJ-0003JV-IR malware acl condition: clamd [127.0.0.1]:3310 : unable to read from socket (Connection timed out)
I'm looking for help with this problem. For now:
restart exim
restart clamd
clear paniclog
in /etc/exim.clamav.load.conf have only
av_scanner = clamd:127.0.0.1 3310
Probably for some reason clamd wasn't running, you may need to check for clmad logs to see why it stopped and maybe rebuild it from CB, DA should take care to check if it's running and restart it if it's not.
Best regards
thanks for tips. I will check it.
Another error
run-parts: /etc/cron.daily/exim exited with return code 123
Thank you! I have last problem ClamAv and Exim -
exim paniclog /var/log/exim/paniclog on serwer.kylos.net.pl has non-zero size, mail system might be broken. The last 10 lines are quoted below.
2017-07-06 08:18:04 1dT06q-0000mv-Dl malware acl condition: clamd [127.0.0.1]:3310 : unable to read from socket (Connection timed out)
ps xa|grep -i clam show that only one proces of clamav is runing.
20128 ?        Ssl    0:05 /usr/local/sbin/clamd --foreground=yes
20171 ?        Ss     0:00 /usr/local/bin/freshclam -d
20185 pts/0    S+     0:00 grep -i clam
In my exim.clamav.load.conf av_scanner is set to av_scanner = clamd:127.0.0.1 3310
In clamd.conf TCPSocekt is the same 3310 and IP is 127.0.0.1 and i clamd.conf I have removed # from LocalSocket /tmp/clamd. (like in this topic http://forum.directadmin.com/showthread.php?t=24792&page=2 )
netstat -ntpl | grep clam -clamd runing
tcp        0      0 127.0.0.1:3310          0.0.0.0:*               LISTEN      20128/clamd
but command clam /clamd status give
ERROR: TCP: Cannot bind to [127.0.0.1]:3310: Address already in use
ERROR: LOCAL: Socket file /tmp/clamd.socket is in use by another process.
Well it say "Address already in use" so something else it is using that port, are you sure you don't have two copies of ClamAV?
How did you install it? Using OS repository AND CustomBuild?
If so, remove the OS one (ex for CentOS: yum remove clamav* freshclam*) and reinstall the CB one (./build clamav)
This may fix your problem.
Another way would be to kill the running process (20128) with killall -9 clamd and restart it again.
Best regards
