FR: Show 2nd PHP release in DA
BBM
Dutch Mountains
I think an installed 2nd PHP release should be shown in the DA's "CMD_SYSTEM_INFO".
Also under PHP configuration "CMD_PHP_SAFE_MODE" I think it should be visible on which PHP release a domain is running.
Maybe even a switch to change the PHP release for the domain.
Yes that would've been a better place. Had a quick look before I posted, but the Feedback-forum didn't catch my eye although it was only 2 down.
(I do also think this is one of those sites where the amount of subforums has gone out of control.)
+1
Would also be very nice to be able to see directly wich php.ini setting file is used by each one.
Kind regards,
Jan
