How to separate HTTPS with main domain and HTTP with alias domain
lowhigh
Hi everybody!
I'm using CB 2 with nginx_apache.
My customer has a account that has 1 main domain and he adds 4 alias domain for his Joomla website, using HTTP, everything is fine.
Today, he buy a SSL for that main domain and it work very well, redirect from HTTP to HTTPS very smothly
But 4 alias domain donot like that, 4 alias domain always be redirected to HTTPS and certainly, the certificate is not for 4 alias domain so they always show the Notice SSL page.
Please tell me, how to config main domain work with both HTTPS and the alias domain only work with HTTP, is there the reason is due to Joomla rules?
Thanks all so much!
The .htaccess file in the public_html directory is probably taking effect over the subdirectories. If they do redirect to HTTPS with .htaccess, that should be it. To fix it, create appropriate .htaccess files in the subdirectores.
thanks wattie!
But i don't understand your ideal.
There is no subdirectoties related here and the .htaccess is get from Joomla 3.6 installation like that:
# @package Joomla
# @copyright Copyright (C) 2005 - 2015 Open Source Matters. All rights reserved.
# @license GNU General Public License version 2 or later; see LICENSE.txt
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE!
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations. It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that disallows changing it in
# your .htaccess file. If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's. If they work,
# it has been set by your server administrator and you do not need it set here.
## No directory listings
IndexIgnore *
## Can be commented out if causes errors, see notes above.
Options +FollowSymlinks
Options -Indexes
## Mod_rewrite in use.
RewriteEngine On
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site block out the operations listed below
# This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to base64_encode data within the URL.
# Block out any script that includes a <script> tag in URL.
# Block out any script trying to set a PHP GLOBALS variable via URL.
# Block out any script trying to modify a _REQUEST variable via URL.
# Return 403 Forbidden header and show the content of the root homepage
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
RewriteCond %{REQUEST_URI} !^/[0-9]+\..+\.cpaneldcv$
RewriteCond %{REQUEST_URI} !^/[A-F0-9]{32}\.txt(?:\ Comodo\ DCV)?$
RewriteRule .* index.php [F]
## End - Rewrite rules to block out some common exploits.
## Begin - Custom redirects
# If you need to redirect some pages, or set a canonical non-www to
# www redirect (or vice versa), place that code here. Ensure those
# redirects use the correct RewriteRule syntax and the [R=301,L] flags.
## End - Custom redirects
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root).
# RewriteBase /
## Begin - Joomla! core SEF Section.
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
# and the requested path and file doesn't directly match a physical file
# and the requested path and file doesn't directly match a physical folder
# internally rewrite the request to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule .* index.php [L]
## End - Joomla! core SEF Section.
My gut feeling is that you first visited the domain pointer by using https, and then your browser cached that, and next time your browser redirect you to https. To rule this out, you should clear all cache and history from your browser, restart it, and test again. Or maybe better use a browser wich you have not used on that domain pointer before.
