SupermanInNY
- Sep 28, 2004
Hi All,
I have a server that is showing no symptoms of failure, except that the sites stop respond.
invoking a 'service httpd restart' brings them back.
# php -v
PHP 5.6.31 (cli) (built: Aug 11 2017 15:41:09)
Copyright (c) 1997-2016 The PHP Group
Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
with the ionCube PHP Loader (enabled) + Intrusion Protection from ioncube24.com (unconfigured) v10.0.0 (), Copyright (c) 2002-2017, by ionCube Ltd.
with Zend Guard Loader v3.3, Copyright (c) 1998-2014, by Zend Technologies
with Suhosin v0.9.38, Copyright (c) 2007-2015, by SektionEins GmbH
t # php -i |more
phpinfo()
PHP Version => 5.6.31
System => Linux server.interuse.com 2.6.32-696.6.3.el6.x86_64 #1 SMP Wed Jul 12
14:17:22 UTC 2017 x86_64
Build Date => Aug 11 2017 15:40:52
Configure Command => './configure' '--prefix=/usr/local/php56' '--program-suff
ix=56' '--with-config-file-scan-dir=/usr/local/php56/lib/php.conf.d' '--with-cur
l=/usr/local/lib' '--with-gd' '--enable-gd-native-ttf' '--with-gettext' '--with-
jpeg-dir=/usr/local/lib' '--with-freetype-dir=/usr/local/lib' '--with-libxml-dir
=/usr/local/lib' '--with-kerberos' '--with-openssl' '--with-mcrypt' '--with-mhas
h' '--with-mysql=mysqlnd' '--with-mysql-sock=/var/lib/mysql/mysql.sock' '--with-
mysqli=mysqlnd' '--with-pcre-regex=/usr/local' '--with-pdo-mysql=mysqlnd' '--wit
h-pear' '--with-png-dir=/usr/local/lib' '--with-xsl' '--with-zlib' '--with-zlib-
dir=/usr/local/lib' '--enable-zip' '--with-iconv=/usr/local' '--enable-bcmath' '
--enable-calendar' '--enable-ftp' '--enable-sockets' '--enable-soap' '--enable-m
bstring' '--with-icu-dir=/usr/local/icu' '--enable-intl' '--enable-exif'
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /usr/local/php56/lib
Loaded Configuration File => /usr/local/php56/lib/php.ini
Scan this dir for additional .ini files => /usr/local/php56/lib/php.conf.d
Additional .ini files parsed => /usr/local/php56/lib/php.conf.d/10-directadmin.i
# httpd -v
Server version: Apache/2.4.27 (Unix)
Server built: Aug 7 2017 00:18:47
As you can see the error_log below doesn't show any issues till we invoke service restart.
[Wed Sep 06 03:30:16.687647 2017] [:error] [pid 20034:tid 140544810333952] [client 74.208.165.33:61961] [client 74.208.165.33] ModSecurity: Access denied with code 403 (phase 2). Match of "endsWith /modules/paypal/express_checkout/payment.php" against "REQUEST_FILENAME" required. [file "/usr/local/cwaf/rules/02_Global_Generic.conf"] [line "24"] [id "211120"] [rev "10"] [msg "COMODO WAF: Remote File Inclusion Attack||www.inaatrxgaomedix.coml|F|2"] [data "Matched Data: ftp://premielo:[email protected]/envi.php? found within REQUEST_FILENAME: /index2.php"] [severity "CRITICAL"] [tag "CWAF"] [tag "Generic"] [hostname "www.inaatrxgaomedix.com"] [uri "/index2.php"] [unique_id "Wa9BmD5ajVAAAE5CD7gAAAAZ"]
[Wed Sep 06 03:30:16.696625 2017] [:error] [pid 20034:tid 140544810333952] [client 74.208.165.33:61961] [client 74.208.165.33] ModSecurity: Audit log: Failed to create subdirectories: /var/log/modsec_audit/apache/20170906/20170906-0330 (Permission denied) [hostname "www.inaatrxgaomedix.com"] [uri "/index2.php"] [unique_id "Wa9BmD5ajVAAAE5CD7gAAAAZ"]
[Wed Sep 06 11:27:38.533884 2017] [core:warn] [pid 22957:tid 140545181153216] AH00045: child process 20852 still did not exit, sending a SIGTERM
[Wed Sep 06 11:27:38.533977 2017] [core:warn] [pid 22957:tid 140545181153216] AH00045: child process 21483 still did not exit, sending a SIGTERM
[Wed Sep 06 11:27:40.536299 2017] [mpm_event:notice] [pid 22957:tid 140545181153216] AH00491: caught SIGTERM, shutting down
[Wed Sep 06 11:27:47.183782 2017] [ssl:warn] [pid 25761:tid 140387976189888] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 06 11:27:47.186460 2017] [suexec:notice] [pid 25761:tid 140387976189888] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Sep 06 11:27:47.186501 2017] [:notice] [pid 25761:tid 140387976189888] ModSecurity for Apache/2.9.2 (http://www.modsecurity.org/) configured.
[Wed Sep 06 11:27:47.186512 2017] [:notice] [pid 25761:tid 140387976189888] ModSecurity: APR compiled version="1.6.2"; loaded version="1.6.2"
[Wed Sep 06 11:27:47.186518 2017] [:notice] [pid 25761:tid 140387976189888] ModSecurity: PCRE compiled version="8.20 "; loaded version="8.20 2011-10-21"
[Wed Sep 06 11:27:47.186523 2017] [:notice] [pid 25761:tid 140387976189888] ModSecurity: LIBXML compiled version="2.9.3"
[Wed Sep 06 11:27:47.186527 2017] [:notice] [pid 25761:tid 140387976189888] ModSecurity: Original server signature: Apache/2.4.27 (Unix) OpenSSL/1.0.1e-fips
[Wed Sep 06 11:27:47.186531 2017] [:notice] [pid 25761:tid 140387976189888] ModSecurity: Status engine is currently disabled, enable it by set SecStatusEngine to On.
[Wed Sep 06 11:27:48.036001 2017] [ssl:warn] [pid 25765:tid 140387976189888] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 06 11:27:48.050160 2017] [lbmethod_heartbeat:notice] [pid 25765:tid 140387976189888] AH02282: No slotmem from mod_heartmonitor
[Wed Sep 06 11:27:48.063284 2017] [mpm_event:notice] [pid 25765:tid 140387976189888] AH00489: Apache/2.4.27 (Unix) OpenSSL/1.0.1e-fips Protected by COMODO WAF mod_fcgid/2.3.9 configured -- resuming normal operations
[Wed Sep 06 11:27:48.063349 2017] [core:notice] [pid 25765:tid 140387976189888] AH00094: Command line: '/usr/sbin/httpd'
Any pointers for where else to look?
Thanks,
-Sup.
# php -v
t # php -i |more
phpinfo()
# httpd -v
Thanks,
-Sup.
