- Feb 27, 2003
We're please to announce the release of DirectAdmin 1.52.0.
As mentioned in the release candidate, this version is many new features and bugfixes.
IMPORTANT SECURITY FIX!
Full list of changes is here:
https://directadmin.com/versions.php?version=1.520000
Some significant changes:
New Features
Bug Fixes
Plus many ... many many more.
To update, go to your Admin Level -> Licenses/Updates, and click update.
Edit: Note, it's important to keep your system up to date.
We recommend using the update notification tool in CustomBuild, see step number 3.
We'll continue to push update requests to servers that are found to still be installing/running old versions.
New Features
- JSON everywhere: Almost done converting all CMD_ functions to JSON for the new skin.
- http2 enabled by default, where applicable.
- mail_sni beta for per-domain SNI SSL with exim and dovecot (replaces dovecot_sni, exim_sni)
- ETags headers for static files
- private_html -> public_html symlink, by default for SSL
- Ability to rename INBOX.spam
- https for redirect type domain pointers
- named-checkzone now more strict using -k fail
- Support for MySQL 5.7 column changes (not yet in CustomBuild)
Bug Fixes
- SECURITY - segfault could allow unauthorized remote access
- LetsEncrypt: clear deleted subdomains before renewal
- Disable user php-fpm before User deletion
- FileManager edit file, save to temp first to prevent 0 byte file on full disk
