- Feb 27, 2003
DirectAdmin 1.52.1 has been released.
https://www.directadmin.com/versions.php?version=1.521000
This is mainly a bug-fix release, plus the last of json items for the new skin, before more intensive skin testing begins.
Also, I have been slowing pushing update requests to all servers older than 1.52.0. We do not normally do this, but have been to ensure everyone has at least 1.52.0.
With this release, you might get pushed from 1.52.0 to 1.52.1, no big deal, but just be aware that it's not a new policy to always update everyone, we only push updates when there is a major need, like security fixes (1.52.0).
So once we're reasonably sure all servers that have done a recent license update have been updated, we'll stop doing update pushes.
Note that CB2 can automatically check and update DA for you, if you want to go that route.
See the "crontab" options in the CB2 documentation and #3 from the basic system security
- Main bugfix is with nginx where the certificates end up being named .combined.combined, due to appending the value from the domain.com.conf file.
- You can now also hide "Script Output: /usr/local/directadmin/scripts/custom/script.sh" for your custom scripts, if you find it annoying
- Also addressed login page username entry with Apple Products (iPhone/iPad) where it always capitalized the first character, which is never going to be true for all lower-case Usernames.
- Moved User Level restores to the task.queue, as larger files took too long in the foreground.
