M michcio29 Verified User Joined Dec 2, 2017 Messages 40 Dec 2, 2017 #1 Hello, I have no Inodes info any suggestions http://prntscr.com/hi33nx
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,228 Location www.poralix.com Dec 2, 2017 #2 Hello, Is inode=1 set in directadmin.conf? Code: /usr/local/directadmin/directadmin v /usr/local/directadmin/directadmin c | grep ^inode
M michcio29 Verified User Joined Dec 2, 2017 Messages 40 Dec 2, 2017 #3 Yes i add but the same result.
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,228 Location www.poralix.com Dec 2, 2017 #4 What is your Directadmin's version? Do you have inodes visible in a default enhanced skin?
M michcio29 Verified User Joined Dec 2, 2017 Messages 40 Dec 2, 2017 #5 1.52.1 yest i set to enhanced skin.
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,228 Location www.poralix.com Dec 2, 2017 #6 OK, you need to contact your skin developer for the fix then.
M michcio29 Verified User Joined Dec 2, 2017 Messages 40 Dec 2, 2017 #7 michcio29 said: 1.52.1 yest i set to enhanced skin. Click to expand... I Mean do not work still
M michcio29 Verified User Joined Dec 2, 2017 Messages 40 Dec 2, 2017 #8 Also i have wrong disc space http://prntscr.com/hi57cj http://prntscr.com/hi580w
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,228 Location www.poralix.com Dec 3, 2017 #9 I guess somebody should check your server. So try and open a ticket with directadmin developers. Or contact me for a paid support.
M michcio29 Verified User Joined Dec 2, 2017 Messages 40 Dec 4, 2017 #10 Fixed Quotas was not Enabling
N nando89 Verified User Joined Mar 14, 2018 Messages 35 May 11, 2018 #11 Default for packages Reseller/Users is unlimited. https://www.directadmin.com/features.php?id=1650 https://www.directadmin.com/features.php?id=1445 Does the server manage you or your ISP? directadmin.conf options set as default: Code: inode=1 Code: user_warning_thresh_inode=95 That shows you: Code: # sudo cat directadmin.conf Last edited: May 11, 2018
