RickDeckard
- Mar 18, 2011
Dear forum users, i read with the right attention here: https://help.directadmin.com/item.php?id=353 and here: https://help.directadmin.com/item.php?id=346
Now in the last step:
i've this error:
ipv6 are added in the naserver configurations too.
PHP:
User Level -> Domain Setup -> domain.com
at the bottom of the page, you'll see "Add another IP to domain.com". Select your new IP, and click "Add IP".
If needed, remove the other IP from the domain's IP list.
i've this error:
PHP:
Could not write domain's db file in /var/named
Unable to save dns zone: named-checkzone returned:
loading "domain.it" from "/var/named/domain.it.db.temp" class "IN"
dns_rdata_fromtext: /var/named/domain.it.db.temp:36: near '2a00:7c80:0000:00b4:0:0:0:4': bad dotted quad
zone domain.it/IN: loading from master file /var/named/domain.db.temp failed: bad dotted quad
zone domain.it/IN: not loaded due to errors.
