Letsencrypt Updates
LawsHosting
London UK
Why are there always problems with CB & LE......
LE update available, you update, build versions still states there's an update to the same version :confused:
Had a problem with Dovecot last week where updating stated it was "done" without even compiling.
What mirror are you using? There was an issue with the latest Lets Encrypt update last week where the version tag in the script itself wasn't updated correctly. If the mirror is up2date and you do ./build update & ./build letsencrypt it should work. :)
See: https://forum.directadmin.com/showthread.php?t=56040
// Edit
I see that you mean another update, the latest 1.0.22, again with the same issue.:eek:
My mistake, sorry guys. It was the version stored inside the .sh script. So you did have the 1.0.22 file, just without that number.
Fixed on files1, md5sum updated too.
Not sure what you're referring to in regards to dovecot. Feel free to create a ticket for any issues.
