A AndrewN Verified User Joined May 26, 2018 Messages 21 Jun 15, 2018 #1 I want to install SSL certificate, how do I install it in direct admin panel ?
trix.hosting Verified User Joined Jun 21, 2016 Messages 59 Location Tucuman - Argentina Jun 16, 2018 #2 Hello, here you have: https://help.directadmin.com/item.php?id=15
A AndrewN Verified User Joined May 26, 2018 Messages 21 Jun 16, 2018 #3 install SSL on sub domain trix.hosting said: Hello, here you have: https://help.directadmin.com/item.php?id=15 Click to expand... Thank you, Is it possible to install the same on sub-domain ?
trix.hosting Verified User Joined Jun 21, 2016 Messages 59 Location Tucuman - Argentina Jun 16, 2018 #4 Yes, use Let's encrypt https://help.directadmin.com/item.php?id=648 enabling it!
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,143 Location www.poralix.com Jun 18, 2018 #5 Hello, If you want a cert for a sub-domain, it should be either included into main domain or the sub-domain should be added as a separate domain with its own public_html/private_html directories.
