A absoonoo Verified User Joined Aug 19, 2015 Messages 32 Nov 6, 2016 #1 Services already be fine but for stop or reload from Service Monitor after click show : Cannot find the script Details /etc/init.d/*.*(service name)
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,113 Location www.poralix.com Nov 6, 2016 #2 Hello, Set Code: systemd=1 in directadmin.conf following this guide: https://help.directadmin.com/item.php?id=641&in1=systemd&in2=1
K kriz Verified User Joined Jul 14, 2018 Messages 9 Jul 14, 2018 #3 It doesn't work I added systemd=1, but it doesn't work. Please help!
Richard G Verified User Joined Jul 6, 2008 Messages 14,926 Location Maastricht Jul 15, 2018 #4 I'm not sure, but are you using Centos 7? If yes... Doesn't that use another location then /etc/init.d for services?
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 7,804 Location LT, EU Jul 15, 2018 #6 Please check: Code: /usr/local/directadmin/directadmin o
K kriz Verified User Joined Jul 14, 2018 Messages 9 Jul 16, 2018 #7 smtalk said: Please check: Code: /usr/local/directadmin/directadmin o Click to expand... It shows: Code: Compiled on 'CentOS 5.0' Compile time: Mar 16 2013 at 22:23:16 Compiled with IPv6 What should I do now?
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 7,804 Location LT, EU Jul 17, 2018 #8 Change the license to a correct one. Update DA manually. If it's a clear server, re-run DA installation. If it already has data on it, I'd suggest running "./build all" from CustomBuild.
