CXS on Directadmin
NaSRi
Hello, I have purchased a cxs license, Unfortunately neither configserver nor directadmin does not provide support it :) such a complicated situation.
I have seen many people could install cxs without any problem but now I cannot figure out the following error.
ClamAV socket [/tmp/clamd.socket] not found
You must install ClamAV (Clamavconnector on cPanel) or ensure clamd is running to use this product correctly
If the clamd socket is not automatically detected, and to clear this message, you must set clamdsock=/path/to/socket in /etc/cxs/cxs.defaults to the live socket location
I have centos 7 and clamAV installed. I have done what the message says though that didn't work out.
I will appreciate if you could share your idea.
As far as I am aware the core of the issue is in PrivateTmp enabled on ClamAV service on EL7 . There are two ways to fix it:
1. Change PrivateTmp to false in /etc/systemd/system/clamd.service file, and restart service:
systemctl daemon-reload
systemctl restart clamd
or
2. Define clamd socked manually - open /etc/clamd.conf, set:
PHP:
 LocalSocket /run/clamd.socket
Restart clamd, then set same path to sicket in /etc/cxs/cxs.default :
PHP:
clamdsock=/run/clamd.socket
or
PHP:
PHP:
Thank you dear, After digging into the /run/ directory I realized that the socket file is located at /var/run/clamd.socket
or
PHP:
PHP:
Hi!
I just registered to DirectAdmin Forum (After some months reading & using people forums!) to thank you!
It really helped me??
