IT_Architect
- Feb 27, 2006
I'm setting up a new server. It is on the same IP as the old one, but a different OS version. I changed it in the license manager. I installed FreeBSD 11.1 on a new VM and everything went fine except the DNS, which I found out how to fix on my own by replacing the named.conf with one from an older install. During this time, FreeBSD 11.2 came out, so I decided to do a fresh install with that since I figured it would be better to do a clean install rather than an upgrade. The IP stayed the same, and matches the license. The install went great, but I have a license file issue now.
When I do a restart it shows:
# service directadmin restart
Stopping DirectAdmin: [ FAILED ]
Starting DirectAdmin: [ OK ]
The log shows:
2018:07:15-13:43:06: Unable to read the license file
I've tried the command line with and without the IP. The feedback is:
# ./getLicense.sh xxxxx xxxxx
shows:
--2018-07-15 14:31:16-- https://www.directadmin.com/cgi-bin/licenseupdate?lid=52463&uid=16785
Resolving www.directadmin.com (www.directadmin.com)... failed: Operation timed out.
wget: unable to resolve host address 'www.directadmin.com'
Error downloading the license file
Error determining IP via myip.directadmin.com
Trying license relay server...
--2018-07-15 14:31:26-- https://license.directadmin.com/licenseupdate.php?lid=52463&uid=16785
Resolving license.directadmin.com (license.directadmin.com)... failed: Operation timed out.
wget: unable to resolve host address 'license.directadmin.com'
Error downloading the license file from relay server as well.
Other:
- I already tried the killall -9 directadmin
- I can ping the DA servers
- It could be because I renewed it on the 11.1 VM?
- The license takes 11.0, and 11.1, but perhaps not 11.2?
The log shows:
shows:
Other:
