IT_Architect
- Feb 27, 2006
DA's CB 2.0 ClamAV 0.100.0 install fails with FreeBSD 11.x
New FreeBSD 11.2 x64 Install
I followed the instructions here https://help.directadmin.com/item.php?id=370. However, it errors out during install:
I thought I would want this maintained by DA as it integrates with Exim and it would take care of all of the settings for me. It doesn't seem to work. Now I'm wondering if it would be better to use pkg? If so, what do I need to do configure DA files manually? (My last experience doing it that was was FreeBSD 7.2 and DA from 2009)
--- libclamav_la-version.lo ---
CC libclamav_la-version.lo
--- libclamav.la ---
CCLD libclamav.la
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_compile.o): relocation R_X86_64_32S against hidden symbol `_pcre_utf8_table4' can not be used when making a shared object
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_exec.o): relocation R_X86_64_32 against hidden symbol `_pcre_default_tables' can not be used when making a shared object
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_fullinfo.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_jit_compile.o): relocation R_X86_64_32 against hidden symbol `_pcre_default_tables' can not be used when making a shared object
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_ord2utf8.o): relocation R_X86_64_32S against hidden symbol `_pcre_utf8_table1' can not be used when making a shared object
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_study.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_valid_utf8.o): relocation R_X86_64_32S against hidden symbol `_pcre_utf8_table4' can not be used when making a shared object
/usr/local/bin/ld: /usr/local/lib/libpcre.a(libpcre_la-pcre_xclass.o): relocation R_X86_64_32S against hidden symbol `_pcre_ucd_stage1' can not be used when making a shared object
/usr/local/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
*** [libclamav.la] Error code 1
make[4]: stopped in /usr/local/directadmin/custombuild/clamav-0.100.1/libclamav
1 error
*** [all-recursive] Error code 1
make[3]: stopped in /usr/local/directadmin/custombuild/clamav-0.100.1/libclamav
1 error
*** [all] Error code 2
make[2]: stopped in /usr/local/directadmin/custombuild/clamav-0.100.1/libclamav
1 error
make[1]: stopped in /usr/local/directadmin/custombuild/clamav-0.100.1
1 error
make: stopped in /usr/local/directadmin/custombuild/clamav-0.100.1
1 error
*** The make has failed, do you want to try to make again? (y,n):
