Read error on update killed mysql
jet1972
Did the default procedure to update DA components:
./build update && ./build update_versions
But this time there were several read-errors with mariadb and the Direct Admin update script apparently did not handle this situation correctly and now mysql server is down!
./build mysql did not help.
How to proceed?
How to proceed?
As no one replied and if some one gets in this same situation here is what I did to solve the problem:
1. Deleted the broken mariadb download file from /usr/local/
2. Proceed with ./build set_fastest && ./build mysql
This solved the problem.
BUT DA scripts should be more robust so this kind of situation should never happen.
My guess is that you was on files6, so many times I see in the forum users having trouble because of broken download from files6.
